GTX 460 SLI power supply
  • Graphics Cards
  • Gtx
  • Power Supplies
  • SLI
  • Graphics
August 31, 2011 9:10:25 PM
I was looking to get a new power supply so I ended up ordering this: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Now I just realized I might get another 460 GTX down the road and put them in SLI with my 2500k. Would that power supply be enough to handle the cards, or should I return and look for a different one.
Also, I won't be overclocking much, maybe just a bit on the 2500k (4.0-4.5Ghz)
More about : gtx 460 sli power supply
September 1, 2011 2:29:19 AM
You need 4 pcie connectors but this only has 2. You could use up your 4 molex/sata for the last 2 pcie but don't look to overclock or high loads for extended times.
m
l
