hi this is my first build parts list. is it compatible? is there any way to improve it? will it be a good build?
cooler master haf 912 plus
http://www.amazon.co.uk/gp/product/B003XEDTLM/ref=s9_simh_gw_p147_d0_g147_i1?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=center-2&pf_rd_r=06MGT00059GB8WGA23SM&pf_rd_t=101&pf_rd_p=467128533&pf_rd_i=468294
intel i7 2600k
http://www.amazon.co.uk/Intel-Sandybridge-i7-2600K-Quad-Core-Processor/dp/B004FA8NOQ/ref=sr_1_1?ie=UTF8&qid=1319448417&sr=8-1
ASUS 1155 P8Z68-V PRO S/L
http://www.amazon.co.uk/Asus-P8Z68-V-PRO-ASUS-1155/dp/B0050AFS84/ref=cm_cr_pr_product_top
radeon hd 6850
http://www.amazon.co.uk/Sapphire-11180-00-40R-6850-GDDR5-Graphics/dp/tech-data/B0047D5S26/ref=de_a_smtd
Corsair 8GB 1600MHz CL9 DDR3 Vengeance Memory Two Module Kit
http://www.amazon.co.uk/Corsair-CMZ8GX3M2A1600C9-1600MHz-Vengeance-Memory/dp/B004CRSM4I/ref=sr_1_1?s=computers&ie=UTF8&qid=1319745171&sr=1-1
Corsair Enthusiast Series TX650 V2 High Performance 650W Power Supply
http://www.amazon.co.uk/Corsair-CMPSU-650TXV2UK-Enthusiast-Performance-Supply/dp/B004O0P9TO/ref=cm_cr_pr_product_top
WD Caviar Green Internal 3.5" SATA Hard Drive - 1TB
http://www.pcworld.co.uk/gbuk/wd-caviar-green-internal-3-5-sata-hard-drive-1tb-09809597-pdt.html
LiteOn 24x DVD-SM Drive LightScribe SATA
http://www.play.com/PC/PCs/4-/19387123/LiteOn-IHAS224-19-24x-DVD-SM-Drive-LightScribe-SATA/Product.html?searchtype=PCSH&searchsource=0&searchstring=dvd+writer&urlrefer=search&strefer=PCSH&searchfilters=s{dvd+writer}%2bc{420}%2b
also could you suggest me a aftermarket cpu cooler thanks
intel i7 2600k
radeon hd 6850
