Hello,
First off, let me start by saying I love Tom's Hardware!
Secondly, I'm having some issues building my first PC, and I'm really hoping someone could illuminate me on where I've gone wrong here. The problem I'm having is I can't seem to figure out how to connect the front panel to the motherboard (the power, reset, and lights specifically). I've got a Rosewill Blackhawk case (the newest one with 2 USB 3.0 connectors) and an ASRock Extreme4 Gen3.
I noticed that the power LED seems to be 3 pins wide instead of two pins wide like all the others, looking at the manual, I'm having difficulties figuring out how they would even connect since the 3 pin seems like it would overlap the power connector. Also, I wasn't 100% certain which one was positive and negative. I'm assuming the common white color is negative given what I've read, but I haven't found anyone else using my exact config.
I've attached some pictures of the front panel connectors, the pins on the mobo, and the page from the manual explaining the pinouts. Can someone please help this lowly noob with his build?
Thanks!!!
Thanks!!!
