How to solve a limited access problem over a wireless network
manish1108
Hello,
I have a problem with my wireless connection bcoz its shows on my laptop in limited access status,so i can't access any internet service ...
plz suggest me hw to fix this problem..
Limited access means you are not getting an IP, are you connecting to a router/access point with DHCP tuned on?
If this is your router(i do not think anyone will help you connect to a router thats not yours), just login on a wired system and have a look
What model or router is it?
