I just recently bought all new components for a new pc and before diving into the issue here are the specs:
Biostar|TZ68A+ Z68 LGA1155 Mobo
Intel core i5 2500k
Asus gtx560 DCII
8G corsair ram 1600
1TB 7200rpm WD HDD
Rosewill Hive series 650W
Once I got everything put together and hooked up, I tried booting the system but there was no power getting to the system. I tried many different things including:
1. running mobo in cardboard box to check for a short-still no power
2. Using a different PSU-yet again no power. I then determined the mobo was DOA
3. New PSU in old system to make sure it wasnt a bad PSU-it turned on but was still unable to boot
4. Got yet another computer from the office(which works fine) and used my new PSU with it-it booted up like normal which makes me think that either my old computer(which was working fine before i tried the new PSU in it) randomly stopped working or whatever happened to my new computer happened to it as well
5. New GPU in pc from office-everything powers on, but motherboard fails to boot BIOS and turns itself off
6. Old GPU from old pc(9800GT) in pc from office-same exact thing as new GPU
The only thing I can think of is the GPU isnt getting enough power, but how can a 650W PSU not be enough? especially for a 9800GT...I also thought maybe the PCIe6+2pin to PCIe6pin was somehow losing power between the conversion(asus requires 2xPCIe6pin power, PSU supplies 2xPCIe6+2pin cables)
I'm really at a loss with this...any help or suggestions would be appreciated. Thanks
Intel core i5 2500k
Asus gtx560 DCII
8G corsair ram 1600
1TB 7200rpm WD HDD
