tv out problems
Forum Graphic & Displays : TV/Video Cards - tv out problems
Ive bought a asusv7700 deluxe car which i conected to my vcr with the composite cable.but i only get the usual tvpicture on the tv. it worked once,but then my vcr broke
(the vcr is repaired know though, and its new)
Sponsored Links
You have to switch to TV out mode under your display properties, if you have Windows, of course.
- Every private citizen has a public responsibility
Reply to Anonymous
i have switched to tv in the settings tab. But my monitor is blank and my tv only shows me tvprograms.
do I have to do something withe my refresh rate, colours or the tv/vcr?
Reply to Anonymous
On my TV I have to switch to a video input signal. There is a little button on my remote that is labelled "input". If you can somehow switch your TV like this you'll probably see it. Strange though, usually if you don't say "yes" to save the settings change, the video will revert back to the monitor. That is how mine works, anyway. I have a Hercules Prophet DDR-DVI (Gefore1 chipset). When I switch to TV mode it usually asks me what format I want to display in. I click on NTSC (National Television Standards Committee) format since I live in the US and then everything is dandy. Not sure if any of this helps. I have a friend with a TNT2 (STB Velocity 4400) card and his won't work either. He gets blank screens on both.
Reply to Anonymous
What kind of connectors does your TV have? I would feel much better about connecting it directly to the TV.
Suicide is painless...........
Reply to Crashman
Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > tv out problems
There are 1295 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
