Tom's Hardware > Forum > Digital Camera > Digital Camera General > Problems with USB card readers
Forum Digital Camera : Digital Camera General - Problems with USB card readers
Archived from groups: comp.sys.mac.advocacy,rec.photo.digital (More info?)
So far I purchased two 12:1 USB card readers to use with my Mac. Both
readers clearly stated on the display cards, Mac OS X compatible but
when I brought them home the software stated otherwise -not compatible
with Mac. Has anyone bought a USB card reader that reads Smart Media
cards and works with the Mac. What brand, model, where.
Sponsored Links
Did you try using it with iPhoto? Try using iPhoto's Import feature to get
images off if it.
Please, no "Go Google this" replies. I wouldn't
ask a question here if I hadn't done that already.
DaveC
me@privacy.net
This is an invalid return address
Please reply in the news group
Reply to DaveC
In article <1113791236.476824.85710@g14g2000cwa.googlegroups.com>,
I've bought several - and all worked fine with the Mac.
What does your do?
If it doesn't work, I'd take it back. It's probably defective. But
first, make sure you're plugging it into the computer or a powered hub
and not the keyboard.
Reply to Anonymous
<malibu.ron@verizon.net> writes:
With OSX you should not need any extra software, USB support is built in.
What happens when you put a card in and plug it in?
Pierre
Pierre Jelenc | New on Home Office Records: Ethan Lipton
| www.homeofficerecords.com www.ethanlipton.com
The Gigometer | Pepper Of The Earth: the HO blog
www.gigometer.com | www.homeofficerecords.com/blog
Reply to Anonymous
In article <d41ffd$2q6$1@reader1.panix.com>, Pierre Jelenc
Hmmm. I have an ancient Delkin card reader that came bundled with some
CoolPix accessories from Nikon. Works fine for me but DOES require a
driver. (OS X supports USB but card readers usually require a driver)
Have you checked your manufacturers website? It's not uncommon to
include the PC drivers but make you download the Mac ones.
Reply to Anonymous
There are 1221 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
