Closed Solved
OCZ Fatality 550W PSU able to power a 6950?
Looking to upgrade my graphics card, here is my current specs:
ASRock 870 Extreme3
8GB of DDR3 RAM
2x HD 4850's
AMD Phenom ll x4 Black Edition 3.2 OC'D to 3.8
Samsung 830 128gb SSD
500GB HDD
Current PSU: http://www.ocztechnology.com/ocz-550w-fatal1ty-series-power-supply.html
Am I in need of a new PSU before I am able to upgrade to this Gigabyte 6950: http://www.newegg.com/Product/Product.aspx?Item=N82E16814125385
Thanks for any help or advice!
5 answers Last reply Best Answer
More about fatality 550w power 6950
  1. Best answer
    The 6950 needs 30 amps to run, if you don't oc you should be able to run the 6950.
  2. Would I still be able to OC as long as I don't flash a 6970 bios, or touch the voltage controls? I would probably just use the AMD Overdrive tool. Not looking to push huge numbers, just need a card for the long run.
  3. Best answer selected by empire501.
    In certain circumstances can also be running overclocking
  5. This topic has been closed by Mousemonkey
Power Supplies OCZ Components Product
