Solved
Mobo RAM Specs/RAM Voltage Issue
I'm building a computer and now I'm looking for RAM for my motherboard. I'd rather buy most of my parts and not have to return any of them because they aren't compatible. My motherboard specs say that it can handle 1.5 volt DDR3 memory. However, when I look at the specs of RAM memory there is a Tested Voltage and SPD Voltage. So if a RAM card says it has a SPD Voltage of 1.5 and a Tested Voltage of 1.65 what is my motherboard's RAM memory voltage specifications referring to, the SPD or Tested Voltage? If it's referring to the Tested Voltage then can my motherboard still use the memory if it requires .15 volts more?
3 answers Last reply Best Answer
More about mobo specs voltage issue
  1. Best answer
    SPD (serial presence detect) Voltage means rdefault voltage and tested voltage is at what voltages the rams cards have been tested. In this case your mobo will support the ram cards.
  2. Thanks for the help.
  3. Best answer selected by Roadkill325.
Memory RAM Motherboards
