I did a bit of a rough draft of a build (my first build) that I want to do. I just want some suggestions, criticisms, and general advice.
Approximate Purchase Date: Next 1-2 months (buy 1-2 pieces every week)
Budget Range: $1000 +/- 200
System Usage from Most to Least Important: Games, Internet, Movies
Parts Not Required: Mouse/Keyboard
Preferred Website(s) for Parts: Amazon, Newegg, TigerDirect, whichever sites have the best price.
Country of Origin: USA
Parts Preferences: Intel i5 2500K seems to be a good bet. Other than that I'm open to suggestions
Overclocking: Yes, even if I don't do it I want the option
SLI or Crossfire: Yes, I definitely want the option
Monitor Resolution: I don't plan on having a huge monitor or multiple montiors.
Additional Comments: Doesn't have to be the best looking thing, just want something that can play games at high settings smoothly. I am looking for that balance between Quality and Cost. My main goal is to be able to play Skyrim on Ultra but I am willing to work up to that gradually.
Some of the parts I came up with-
This is just what I came up with in one night of research. If you have any kind of comments, recommendations, opinions, don't hesitate to post them!
Motherboard: ASRock P67 EXTREME4 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard- $160
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157229
Processor: Intel Core i5 2500k- $214
http://www.amazon.com/Intel-i5-2500K-Processor-3-3GHz-LGA1155/dp/B004EBUXHQ/ref=sr_1_1?s=electronics&ie=UTF8&qid=1320032069&sr=1-1
Graphics Card: I was thinking either 2 HD 6850s or 2 GTX 460s (Each around $150 on various sites). I don't know if I should get two cheaper cards or one expensive card. This is one area I would really appreciate recommendations,opinions, any advice.
SSD: RealSSD C300 Solid State Drive 64G $80 (Used)
http://www.amazon.com/gp/product/B003SV6CIC/sr=1-12/qid=1320031962/ref=olp_product_details?ie=UTF8&me=&qid=1320031962&sr=1-12&seller=
HDD: No prefference at the moment. Around $90
DVD: Would like to have a DVD burner $30-$50
Power: CORSAIR Professional Series HX750 (CMPSU-750HX) 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS SILVER Certified Modular Active PFC Power Supply $137
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
Memory: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 $49.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
Case: Probably a Midtower I would like to spend about $50-$120 I don't mind spending on a decent case.
