Ati Radeon HD 5770 running upwards of 100 C under 95% GPU Usage.
As the title says. Is this normal? Should I be worried?
6 answers Last reply
More about radeon 5770 running upwards usage
  1. Looking at MSi Afterburner right now, its running at 87C with only 2 tabs of Google Chrome open, and WoW running in the background on low settings. As well, the GPU Usage is at 8%. Something seems amiss.
  2. Something seems fishy. I don't think that card should get that hot. How long have you had it?
  3. About a year. I am looking to upgrade, but the money for a new card hasnt materialized into my pocket yet. I just cleaned the hell out of it, so let's see if that will help.
  4. That kind of temperature isn't caused by dust. A few questions. How long have you had the card; did you receive it in this condition or has it just started to heat like that?
    Make sure that the fan on the card is operating at all times. Sometimes a catalyst update will cause strange things to happen like fan problems and the such. If it isn't you may try setting it to manual fan control in the catalyst control center.
    If that did not help give me some more information before I continue.
  5. I built the computer back in September of 2010. The card came in perfect condition and I havent had any problems with it until about 3 months ago. I can hear the fan working. I set the fan to 100 percent just in case when i get on something like WoW or LoL. When I'm not running a game of some sort, it idles around 50C or so.
  6. Is your card still under warranty? If so that is the route I would suggest. Otherwise it could be something with the heat sink / thermal paste. If it were a more expensive card I would recommend replacing that but seeing as you can buy a new card for that much it would be a better route aside from using the card warranty.
Graphics Cards GPUs Radeon HD ATI Graphics
