I have a Seasonic X Series 850W psu and a Gigabyte GA-Z77X-UP4 TH motherboard. I started the assembly and had trouble fitting in the 24 pin connector to the motherboard. I had them in the right orientation and there is nothing to suggest that the fit is incompatible. I plugged in the CPU power supply cable just fine. Is this more likely to be an issue with the PSU or MB manufacturers, or an entirely separate issue? Thanks for the help.
