Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Sound Cards > Need help choosing Sound Card
Forum CPU & Components : Sound Cards Need help choosing Sound Card
Hi guys,
I just finished my new gaming rig, and would like to add a sound card to it just to produce better sound.
Im currently using windows 7 HP and 7.1 headphone (or maybe its virtual) Sony DR-GA500.
http://cdn.head-fi.org/1/1f/1fd28c8a_IMG_6598.jpg
On my motherboard, the only slots open is PCI, ( i saw some of the sound cards are pciex, and that is not possible in my build).
Im willing to spend 150-200 dollars, can you guys recommend me a good sound card for gaming and music? (80% gaming.) The Sony headphones also uses 5 cables of 3.5mm jacks(right now connected to 3.5mm jacks rear panel mobo) to produce 7.1, and im not really familiar with audio setups, so should the sound card have 5 3.5mm jacks or no?
http://i1096.photobucket.com/albums/g327/love-taiwan/new%20arrival/SonyDR-GA500-3.jpg
Please help me :)
and if you read until here, i appreciate it
Thank you!
ps:pic taken from google.
Message edited by magicvipre on 02-01-2012 at 06:50:37 AM
Reply to magicvipre
Asus Zonar ...... Series check them out.
------------------------------ Passiveness causes others to pass us by
http://valid.canardpc.com/cache/banner/2026250.png
Reply to alyoshka
How muc you willing to spend? The best Price/Performance right now is the ASUS Xonar DX, though since you have to use PCI, the ASUS Xonar D1 is the card you want. You also might want to look at the Auzentech Mediain 2G.
Reply to gamerk316
Hi there, thank you for the reply.
My Mobo is Asus P8z68-vpro/gen3, it has 3 pcie16x slots, one blue, one light blue and one black colored. I think I can move my GPU (R7970) to the light blue which will give me a free PCI and PCIex1 slot(the smallest pci) and have the R7970 work at x16 right?
I am sure that the black colored works only at x4.
I am willing to SPEND $0-$200 for the sound card.
My concern is that, can I connect my Sony processor to the xonar d1? My guess is it can, but not sure (im blind at sound cards).. http://www.overclockersclub.com/vimages/asus_xonar_d1/07.jpg
Is there any other sound card u think its compatible for my headset and can produce 7.1? willing to spend 200 bucks for this..
Thank you! :)
PS : im also using 1 PCI slot for my wireless n adapter.
theres 2 PCI slots, 2 PCIex1, 3 PCIex16
Message edited by magicvipre on 02-01-2012 at 10:44:54 PM
Reply to magicvipre
With the Xonar, you won't feel the need to use the Sony DR-GA500. You can use the Xonar DX in the last fullsized PCIe16_3 Black slot on that board too. It is compatible with that PCIe slot.
http://www.asus.com/Multimedia/Aud [...] /#overview
If you feel you want to connect it to the Sony DR-GA500 then you can go ahead but I would really wonder why,, if you went ahead and did that.
Although if I were you, and had that budget, I'd go for the Xonar D2X
Currently unavailable/out of stock at newegg
http://www.newegg.com/Product/Prod [...] 6829132005
I would even go for something from Auzentech but currently nothing is available on newwegg from them.
http://www.auzentech.com/site/prod [...] dian2g.php
or
http://www.auzentech.com/site/prod [...] ravura.php
Message edited by alyoshka on 02-02-2012 at 05:45:06 AM
Reply to alyoshka
I would go for that Xonar D2X, but I cant find anywhere that is in stock.. Even at Newegg.com or amazon.com.
So, I guess you think that auzentech is better than Asus's sound cards?
Also, you mean that with the Xonar DX, it can give me equal performance just like the Sony Processor?
By the way, without any sound card, The Sony DRGA500 has dts option settings in Sound in Control panel, but it is all greyed out, there is no driver at all for this headphone..
PS: im using windows 7 hp.
Reply to magicvipre
No, the Xonars are the best that are out there, but are being held back because of drivers. The Auzentech cards are at par with the Xonars and so they are both the best, I'd get either ones , depending on availability and after sales services.
Oh yes, these cards are certified sound processors and have all the required chips onboard to decode and encode various sound streams.
Reply to alyoshka
xonars are so are creative labs latest offerings
sounds like you need a usb sound card solution
ceck out recon 3d usb setup
Reply to triny
No USB sound solutions...... they're no good and certainly no match for a PCIe Soundcard.
Reply to alyoshka
The Recon3d series STINKS. Just about everyone I've talked to basically confirms they are a step back from teh X-fi line [which I don't hold in high regards anyways...]
Right now, ASUS/HT Omega/Auzentech are the way to go. Best PCI options:
ASUS Xonar D1
ASUS Xonar D2
Auzentech Meridian 2G
HT Omega Halo+
HT Omega Claro XT
ASUS Essence ST
The D2, Meridian 2G, and Halo+ have very simmilar feature sets, and are all based off the same exact C-Media chipset. I used the D2 and was happy with it, but the Meridian 2G is a newer refresh, and probably the best of the three.
The Essence ST is, frankly, the best soundcard on the market right now. Problem is, it has a different feature set then what you need [Stereo RCA and a headphone amp].
Best PCI-E options [assuming you get a slot free:]
ASUS Xonar DX
ASUS Xonar D2X
ASUS Xonar Xense
Auzentech Home Theatre HD
ASUS Essence STX
Obviously, you have options. Anything that includes 7.1 analog output should be able to connect to your headset without a problem.
Reply to gamerk316
There are 1924 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 4 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
