Advice on system
Last response: in Systems
November 1, 2011 6:57:59 AM
Looking for advice on this system i intended to mainly use it to play games, but to also edit videos
  1. 1 x AMD Phenom II X6 AM3 1100T Black Edition (3.3Ghz) 64-Bit Six-Core CPU - $245.30 (includes freight and cc)
  2. 1 x 2000Gb 2TB Western Digital Caviar Dual Processor Black SATA-II hard disk - $345.40 (includes freight and cc)
  3. 1 x ASRock 990FX EXTREME3 AM3 990FX ATX M/B - $209.00 (includes freight and cc)
  4. 1 x 850W Corsair AX-850 ATX Power Supply - $275.00 (includes freight and cc)
  5. 1 x Gigabyte AMD HD6970 PCI-E 2.0 2GB GDDR5 Video Card - $426.80 (includes freight and cc)
  6. 1 x 90GB Corsair Force Series 3 SSD - $191.40 (includes freight and cc)
  7. 1 x 16GB Corsair Twin3X 240-pin DDR3 1600Mhz PC-12800 Pack - $148.50 (includes freight and cc)
  8. 1 x MS Windows 7 Professional 64-bit DVD - $163.90 (includes freight and cc)
  9. 1 x LG BH12LS38 Black Blu-ray Writer SATA Drive - $138.60 (includes freight and cc)
  10. 1 x CoolerMaster HAF 932 Advanced Black Aluminium tower case - $200.20 (includes cc)
  11. 1 x CoolerMaster V6 GT Universal CPU Cooler for Intel Socket LGA1366 / 1156 / 775 and AMD Socket AM3/AM2+/AM2 - $100.10 (includes freight and cc)
  12.
  13. Total: $2444.20
Im still undecided about cross-firing my GFX but im leaning towards doing it
More about : advice system
November 1, 2011 7:16:09 AM
Im sure that system will work well. Looks like you have chosed some good quality components.
5. Take a look at the PNY GTX580 card as an alternative to the 6970. This has a closed loop water cooling system on it, and has had some great reviews. There are two versions of the card. One version cools your cpu and your video card on a single system.
6. Personally i would spend a little bit extra and go for a 120 GB corsair ssd drive. Very little cost difference for 25% more capacity.
7. Check the compatibility chart from your mobo manufacturer for the ram chips. That way you will be getting the most compatible chips and save yourself an lot of time and effort.
11. You wont need a cpu cooler if you have a PNY water cooled graphics card (with cpu cap)
m
l
November 1, 2011 7:26:15 AM
Yeah ok ive swaped out the SSD for "120GB Corsair Force Series 3 SSD, SATA 6Gb/s, Sandforce SF-2200 controller, Read 550MB/s, write 510MB/s"
m
l
a b B Homebuilt system
November 1, 2011 7:39:48 AM
I can't see building an MAD based box at any price point above $800. And any MoBo chosen would have to have a 3 or 5 year warranty
For video, I'd be using a Segate Barracuda XT 3 TB
http://benchmarkreviews.com/index.php?option=com_conten...
ANd yes, I'd want a 120GB SSD with at least 50 MBps read performance
The HX850 gets a 10.0 performance rating @ jonnyguru and is cheaper than the 9.5 rated AX850
Video editing and a non CUDA enabled GFX card ?
http://www.studio1productions.com/Articles/PremiereCS5....
Twin 900 MHz 560's would cost ya about $410 here in the US.
V6 GT sounds like you live next to an airport. Consider the Silver Arrow which is a half degree behind but almost dead silent
For RAM I'd use two of these:
Consider the Antec 1200 or DF-85 w/ CP-850 as it easily matches, if not surpasses your original choices but at a much lower cost:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=...
Quote:
It is completely unmatched by any ATX unit on the market I can think of. You'd have to spend twice as much as this thing costs to find the next best thing, performance wise.
http://www.silentpcreview.com/article971-page7.html
m
l
November 1, 2011 8:11:12 AM
OK based on the advice so far ive change it into this
  1. 1 x Thermalright SILVER ARROW CPU Heatsink and Fan for Intel Socket 775/1156/1366 - $130.90 (includes freight and cc)
  2. 1 x 3000Gb 3TB Seagate Barracuda XT 7200.12 7200RPM SATA-6G/sec hard disk - $422.40 (includes freight and cc)
  3. 1 x AMD Phenom II X6 AM3 1100T Black Edition (3.3Ghz) 64-Bit Six-Core CPU - $245.30 (includes freight and cc)
  4. 1 x ASRock 990FX EXTREME3 AM3 990FX ATX M/B - $209.00 (includes freight and cc)
  5. 1 x 850W Corsair AX-850 ATX Power Supply - $275.00 (includes freight and cc)
  6. 1 x Gigabyte AMD HD6970 PCI-E 2.0 2GB GDDR5 Video Card - $426.80 (includes freight and cc)
  7. 1 x 120GB Corsair Force Series 3 SSD - $224.40 (includes freight and cc)
  8. 1 x 16GB Corsair Twin3X 240-pin DDR3 1600Mhz PC-12800 Pack - $148.50 (includes freight and cc)
  9. 1 x MS Windows 7 Professional 64-bit DVD - $163.90 (includes freight and cc)
  10. 1 x LG BH12LS38 Black Blu-ray Writer SATA Drive - $138.60 (includes freight and cc)
  11. 1 x CoolerMaster HAF 932 Advanced Black Aluminium tower case - $200.20 (includes cc)
  12.
  13. Total: $2585.00
m
l
