Sign-in / Sign-up
Whats the best cooling system
  • Cooling
  • ATX
  • Components
  • Product
Last response: in Components
February 1, 2012 6:46:03 PM
im getting 2 pcs one 4 my bro pls tell me what cooling system i should get 4 these 2 builds
build 1
xl-atx CM storm trooper case
i5 2500k cpu
intel h67 mobo
1000 watt atx xtreme gaming psu
8g kingston ram
2tb sata hard drive
sony 24x multi op drive
amd radeon 6950
build 2
intel DX79SI mobo
i7 3930k cpu
g skillz ripjaws z series 16g ram
3 amd radeon hd 7970's
sata 2tb hard drive
120gb ssd
sony 24x mulit op drive
More about : whats cooling system
February 1, 2012 6:49:49 PM
Those psu's are bad...also I would get a p67 or z68 board for the 1st build. How much are you willing to spend for cooling?
m
l
February 1, 2012 7:37:09 PM
id spend up to 130-150 $ on cooling and if those psu's are bad what psu should i get
m
l
February 1, 2012 8:58:18 PM
Definitely P67/Z68 for the first build. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
That second build is intense. Note that neither needs a case that expensive, and you should choose your case by stylistic preference. If you like the look of the Trooper, stick with it.
I'd drop to a 1tb HDD and get a 256gb SSD on the second, and also get a 1tb on the first build and add a 120gb SSD. They really make a difference.
PSUs, assuming you're going to upgrade to two non-580 GPUs on the first build:
first: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
second: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
The first system will be fine with a $35 Hyper 212 EVO, or a $50 Mugen 3 if you feel like spending more. The second should probably be the Mugen.
212 EVO: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Mugen 3: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Data: http://rwlabs.com/article.php?cat=&id=454&pagenumber=6
There's nothing on that list that competes with the Mugen at its price.
m
l
February 1, 2012 9:48:13 PM
the best overall air cooler is probably the noctua nh-d14. it looses to the thermalright silver arrow but only by a degree or two. the noctua has the best ram compatibility though as the silver arrow only accepts low profile ram.
m
l
February 1, 2012 10:17:25 PM
Are you xtremegamer2da max?
m
l
February 2, 2012 12:19:15 AM
no that would be my brother
m
l
February 2, 2012 12:50:42 AM
Tell your bro, that the dx79si isn't that good of a board compared to other x79 boards.
m
l
February 2, 2012 5:19:04 AM
Have you ever considered custom liquid cooling? An xspc rasa rx120/240/360 would be good for beginning water cooling. It will fit very snug in each one of your choices and look very nice.
m
l
February 2, 2012 9:47:02 PM
A family with their cash priorities straight? :D
m
l
