Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > Is this power supply rubbish?
Forum CPU & Components : Power Supplies, Cases & Mods Is this power supply rubbish?
i bought it with my dad, who is an electrician ... Looked it up online after buying it and apparently its like those other chinese time bombs and will take my system with it in a few months etc. :kaola:
http://www.maplin.co.uk/680w-g7-po [...] 1&t=module
Reply to matthew1994
Looks pretty generic, now if you're just surfing the web and typing up word documents, then this PSU might suffice as i would only go for generic branded PSU's if i know the system won't be stressed with handling games and other resource intensive tasks that will stress the PSU out. Also if that is what you would plan to do with the system then the wattage is too high on that unit.
It is recommened to always go for name brand when it comes to power supplys, the more quality the unit the better as if you go generic and the software you run puts to much stress on the low quality compnents inside the unit then it could take other parts out with it, so if you plan to game or do video editing/CAD work etc. then i'd choose from a more reputable brand like Corsair, Thermaltake, Silverstone etc.
Reply to CDdude55
also Antec,Seasonic,XFX all make some good psus
CDdude55 advice is pretty good
I just wanted to add those brands in :)
------------------------------ "I yam what I yam and thats all that I yam"-Popeye-greatest 20th century philosopher
[http://valid.canardpc.com/cache/banner/2375043.png
Reply to king smp
You should get a PSU from a more reputable brand. You can find some that cost that much.
Reply to phamhlam
- -1 +
All the above brands are good except Thermaltake. They make absolute crap that can kill your computer it's so bad out of spec. You might want to remove them from your recommend list.
I usually recommend Corsair, Seasonic, PC Power and Cooling, XFX, Silverstone, Enermax and Antec.
------------------------------ i7 2600K @ 4.5/P67A UD4/Scythe Mugen 2 Rev B/OCZ Vertex 2 120GB/2xWD 640 Blacks/Antec 1200/Samsung 23in LED LCD/EVGA GTX 460/2x4GB GSkill Ripjaws X DDR3 1600 7-8-7-24/Windows 7 Ultimate x64/Corsair 750TX
Reply to anort3
- 1 +
not true. some of thermaltakes psu's are great. the 1 i have is excellent... i have the 850w toughpower its nearly 3 years old and i have had zero issues and its whisper quiet even at load. yes some of there lesser units i wouldnt use as doorstops but some are well made... the reason ? they get them made by 3rd parties. the end result is inconsistent products.
that G7 is hit and miss in the reviews. 3 out of 5 people claim it killed there pc or developed a fault very quickly... so no i wouldn't chance it... better to get a coolermaster 550w for the same money... if your running a single card you wont need any more than that...
Message edited by HEXiT on 02-02-2012 at 12:58:46 AM
------------------------------ |i7 920 D0@3.6 |CNPS10 flex |ex58-ud5 |6Gig 1333 C7 |HD 5870
|G11 keyboard|X-fi Xtreme |G930 |3x1tb SpinPoint f3's raid 0 |thermaltake tp 850watt |antec 902
|Rat 7 contagion |Razer Destructor mat |bamboo pen'N'touch | 3d pro stick |nitro wheel |360 pad
Reply to HEXiT
- 0 +
These are rated by ripple and noise. The best Thermaltake makes is a tier 3. That list is not perfect but it is pretty accurate and updated.
http://www.eggxpert.com/forums/thread/323050.aspx
Thermaltake is the only brand listed above that makes something this bad.
http://www.hardwaresecrets.com/art [...] view/902/9
In my opinion there is no reason to recommend a brand that is so hit and miss when so many other brands are not.
Reply to anort3
- 0 +
im not sure about the eggspert link as im pretty sure the thermaltake 650w unit is a fire hazard but its listed as a reasonable unit... i know the 850w is good but there 500-650w and there 750w tr rx models were made by a less than reputable maker which in turn lead to a lot of complaints, returns and dead systems.
your rite in saying you wouldn't recommend them but i would if they were talking specific units... while i would also tell a buyer to stay away from specific lower power offerings. each to there own i guess on this 1.
Reply to HEXiT
Tier 3?
Anyway... just check this list. If its an HEC or Solytech Thermaltake unit, don't buy it. The Sirtec, FSP's and CWT's are safer. The Enhance made ones will be their best.
I thought they were trying to improve their image, but I see a whole new line of Solytech units... psha.
Reply to totalknowledge
There are 1947 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 4 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
