Approximate Purchase Date: End of November
Budget Range: 600-625.
System Usage from Most to Least Important: Home, gaming, surfing the internet, watching movies,Software Development, computer virtualization (eg:VMware)
Parts Not Required: keyboard, mouse, monitor, speakers, OS
Preferred Website(s) for Parts: www.amazone.com
Country of Origin: some where in latin america lol
Parts Preferences: N/A
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: 1280x1024
Additional Comments:
Hi All, i'm trying to build my new computer and i wanted to be AMD X6 so i can use virtualization with this to work on some software development.. but i want it also for fun, gaming and general use... so this is what i found so far... i'm not in the US so newegg its unfortunatly not an option so i decide to go amazon.com , my question for this will be :
1. The PSU i selected will be able to handle all the selected parts ?
2. is the motherboard a good choice or should i go with other brand or model ?
3. will the ram be good with this motherboard ? ... its not on the specs of tested Ram of ASRock motherboard ..
4.will the ATI video card be supported by the processor or isn't this an issue ?
5. what will be a good Hard Drive to put on ?
If you have any better suggestion it will be very very appreciated or if you have a better configuration please feel free to tell me. thanks again for all you´re help in advance.
ASRock 870 EXTREME3 R2.0 Socket AM3+
AMD 870 Quad CrossFireX SATA3 and USB3.0 A&GbE ATX Motherboard - 870 EXTREME3 R2.0 $110.43
http://www.amazon.com/ASRock-870-EXTREME3-R2-0-Motherboard/dp/B005DXC8CC/ref=sr_1_5?ie=UTF8&qid=1318386408&sr=8-5
XFX AMD Radeon HD 6870 900M 1 GB
DDR5 DUAL MINIDP HDMI DUAL DVI PCI-E Video Card (HD687AZHFC) $170
http://www.amazon.com/XFX-Radeon-MINIDP-Video-HD687AZHFC/dp/B005C31F2M/ref=sr_1_7?ie=UTF8&qid=1320171776&sr=8-7
AMD Phenom II X6 1055T Processor (HDT55TFBGRBOX) $150
http://www.amazon.com/AMD-Phenom-1055T-Processor-HDT55TFBGRBOX/dp/B003FVNC0Q/ref=sr_1_1?s=pc&ie=UTF8&qid=1318918234&sr=1-1
Corsair XMS3 8 GB (2 x 4GB) 1333 MHz PC3-10666 240-Pin DDR3 Memory Kit CMX8GX3M2A1333C9 $38
http://www.amazon.com/Corsair-PC3-10666-240-Pin-Memory-CMX8GX3M2A1333C9/dp/B003N8GVUY/ref=pd_bxgy_e_img_b
Corsair Enthusiast Series 650-Watt 80 Plus Bronze Certified
Power Supply Compatible with Intel Core i3, i5, i7 and AMD platforms - CMPSU-650TXV2 $91.77
http://www.amazon.com/Corsair-Enthusiast-Certified-Compatible-platforms/dp/B004LB5AZY/ref=pd_sim_sbs_e1
Overclocking: No
