New Motherboard+CPU help.
Hey all, I've recently purchased an AMD 7970 3gb. But it's not quite performing as expected.. not the best fps on farcry3 and hitman etc.
I think it might be due to a cpu/mobo bottlekneck..
current specs are:
ASUS P8P67 Deluxe (rev2) < So no pci-e 3.
6gb 2000mhz running at 1866mhz due to mobo compatibility, Just bought 8gb at 1866mhz for £25 on amazon though (awaiting dispatch)
1TB SATA HDD 7200Rpm and 320Gb same spec.
CPU i5 2500 @3.3ghz (Not K version)
So I was wondering what you guys think about the set-up? Is an upgrade required? or is it Drivers?
Im thinking of spending another £350 on cpu and motherboard as I don't have alot to spend and ideally would rather spend £320.
Look forward to your responses,
Thanks.
More about : motherboard cpu
thanks for the reply, yeah im running the 12.11 Beta Drivers already. my PSU is 1000w, I was running 1gb 460s in SLi previously and I think they ate more power than the 7970.
Im just looking at other peoples benchmarks on Farcry3 or Hitman and they seem to be getting a steady 60fps on hitman.
im on about 45-50's in hitman with no AA, and about 20-30fps on farcry ultra settings with Multisample anti-aliasing at 2. So it's pretty pathetic really. I decided to turn off AA in farcry but it looks pretty lame & I didn't think I would have to do that as other people haven't.
