I need a motherboard for i7 930 plz help
Last response: in Components
Motherboard Expert
if you go for gigabyte you may need to check memory compatibility if its ddr3 1600. for some reason the ud3 and ud5 boards not like some brands at that speed... mine (ud5) for instance doesnt like my ocz 1600, i have to run it at 1333 but i also run at lower latencies because of it meaning i dont loose any performance in real terms.
Ask the community
