Gigabyte UD5h Problem help!!!!!!
December 5, 2012 9:56:57 PM
New build everything went great then I had to open up the computer to test a new video card I accidently pressed the Clear CMOS button and when i turned it on it went to the bios setup so that i could load the defaults or enter bios. BUT IT WILL not reconginze my keyboard and i have been trying to find a way to get it to work :(  i have tried every port but it just won't work i need some help please.
running
Gigabyte UD5H motherboard
PSU 750w
G510 keyboard
16gb ram evo corsa
120gb ssd
More about : gigabyte ud5h problem
a b V Motherboard
December 6, 2012 12:54:12 AM
Z77X-UD5H ? Did you disconnect power cord during configuring your devices in the case?
Maybe you have shorted the devices and some of them were damaged.
Try to unplug everything and return them in correct place, unplug power cord too and plug it again.
m
l
December 18, 2012 12:23:13 AM
Has the keyboard ever worked in BIOS?
What version of BIOS is currently on the Motherboard?
Flash BIOS to F14 and that should fix it up..
USB Keyboard compatibility was updated in F7 i believe
m
l
