Approximate Purchase Date: within the next few months
Budget Range: 700-900 After Rebates
System Usage from Most to Least Important: gaming, surfing internet, streaming video although streaming is not all that important.
Parts Not Required: monitor, keyboard, or mouse.
Preferred Website(s) for Parts: either newegg.com, or tigerdirect.com would consider amazon or walmart for mainstream parts like memory and vid cards if available.
Country of Origin: US
Parts Preferences: by brand or type I prefer intel over AMD for processor, and Nvidea over ATI. other than that, I'm looking for good quality for a good price. I'm open to all suggestions relating to memory as well.
Overclocking: No
SLI or Crossfire: Yes, I want to be able to do SLI down the road, but don't nessesarily want to incur the additional expense of the 2nd card right now.
Monitor Resolution: 1600x1200, 1680x1050, 1920x1080, 1920x1200)
Additional Comments:
Would like to have a quiet machine, at least as quiet as a PC can be with 2 vid cards, fans, etc.
Key would be to have the capability to upgrade a good amount to keep the machine relatively current for the next 4-5 years without doing a complete system overhaul. Would need to have plenty of juice to run all current and upcoming games (diablo 3, starcraft 2, etc.) on at least high setting.
Parts I am looking at...
Motherboard - MSI P67A-G45 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130582
I'm thinking this might be overkill, I'm open to suggestions to change this as long as it supports SLI, and has the L1155 socket for my i5 chip. I'm not sure about which chipset I should be looking at.
CPU - Intel Core i5-2500 Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115073
I looked at the i7, and I like hyperthreading, but from what I read its impact on gaming is minimal. I won't be doing much video editing or streaming content really.
Case - Antec Nine Hundred Two V3 Black Steel ATX Mid Tower Gaming Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129097
might be a situation where I saw the pretty blue LED lights on the case and said, I have to have that... I think I could find a lower price case than this. I just really want it to be quiet and have enough fans and room to cover the heat of SLI cards once I add the 2nd. maybe this one?
Rosewill DESTROYER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 120mm Fan, 1x Top 120mm Fan, 1x Rear 120mm Fan, option Fans-2x Side 120mm Fan, 1x Top 120mm Fan, 1x Bottom Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147144
Power Supply - CORSAIR Enthusiast Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
This may be a stupid question, but does a power supply need to say SLI or Xfire ready to be able to power it? 650w should cover all these needs with room to spare so i don't overtax it, but I'm not 100% sure I did the calculations right.
Video card - GIGABYTE GV-N56GOC-1GI GeForce GTX 560 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125383
i've always like the nvidea cards more than the ATI, and is there much of a differenct between the same card made by gigabyte, msi, evga, etc? They all have the same card, but slightly different prices.
Memory - Kingston 4GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model KVR1333D3N9/4G
http://www.newegg.com/Product/Product.aspx?Item=N82E16820139046
I'll be getting 2 sticks for a total of 8GB. Is there an appreciable difference between memory with a 8 or a 9 CAS rating? what about getting 1333 vs 1600 speed? seems like common opinion is that 1333 is what is used unless you are overclocking...
Hard Drive - SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
I can probably get away with a 750gb drive, I have a 250 gb external drive thats not even 1/4 full and my internal is 80gb, and that's only 3/4 full.
dvd drive - LG CD/DVD Burner Black SATA Model GH22NS70 OEM - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136238
thought about blue ray player, but i won't be using one on my PC, I have a regular one. I'm not dead set against getting one for the PC though.
Any help or refinements would be appreciated.
Overclocking: No
