Can anyone tell me what my problem is here? I just got done building this pc, and every time I turn it on, before windows loads it gives me a warning that says my cpu is overheating. Bios says the temperature is at about 97c, but it then quickly goes down to about 50c. Core temp says it runs idle at about 50c, but under any kind of load it quickly jumps up to 80 or 90c. The voltage varies between about .98 and 1.3. I'm using the fan that came with the CPU, as well as two front intake fans and an exhaust fan in the back of my case. I even took off the side of my case to see if that would make a difference. When I put my hand by the cpu fan, I don't feel a lot of heat coming off, but I don't know if that means anything. I updated my bios and everything. Even when it runs at 80 or 90c it doesn't seem to slow down or anything.
Here is what I have:
CPU: i5-2500k
Motherboard: Asus p8p67 rev. 3.1
Memory: 16gb crucial
PSU: Corsair tx750
GPU: Radeon HD 6870
This is my first build, so I'm not really a veteran or anything. It seems to cool down and heat up really fast. It cools down from 90c to 40 or 50c in about 10 seconds. I was thinking it might be a faulty heat monitor, but I don't really know. If there is anyone that can help, please let me know.
CPU: i5-2500k
PSU: Corsair tx750
GPU: Radeon HD 6870
