S5000XVN Intel Power Signal Connector
Power Supplies
Intel
- Power
Components
Last response: in Components
kingzx87
February 3, 2012 12:57:03 AM
Hi i have a Intel S5000XVN, and have ATX Power Supply. The motherboard need a power signal connector my ATX power supply dont have this conector is a conector of 5 pins
Power Supply Signal Connector Pin-out (J9D1)
Pin Signal Color
1 SMB_CLK_ESB_FP_PWR_R Orange
2 SMB_DAT_ESB_FP_PWR_R Black
3 SMB_ALRT_3_ESB_R Red
4 3.3 V SENSE- Yellow
5 3.3 V SENSE+ Green
and need a temp sensor
, is posible run this motherboard without these connections Power signal and temp sensor? is posible create this conector?
Power signal connector:
Help Please!!
Pin Signal Color
, is posible run this motherboard without these connections Power signal and temp sensor? is posible create this conector?Power signal connector:
Help Please!!More about : s5000xvn intel power signal connector
kingzx87
February 4, 2012 3:28:43 AM
- Intel S5000XVN server motherboard - Forum
- Intel s5000xvn and ram - Forum
- Intel S5000XVN & S5520SC - Forum
- Intel DG41RQ has 6-pin PCIE power connector ?? - Forum
- Can i connect only 1x4 Cpu power connector in Intel S3000ah motherboard - Forum
kingzx87
February 4, 2012 3:40:51 AM
kingx87 are you neverdie from http://www.eggxpert.com/forums/thread/791883.aspx
Score
kingzx87
February 4, 2012 4:01:08 AM
kingzx87
February 4, 2012 4:02:00 AM
kingzx87
February 4, 2012 9:01:36 PM
kingzx87
February 6, 2012 5:09:51 AM
the led i talk is: Status LED The status LED indicates whether a system is
operating correctly, has experienced a minor fault, or
a major system error. For details about this LED, see
the Technical Product Specification.
the pdf say:
Amber Solid on Critical, nonrecoverable
Fatal alarm – system has failed or shut down
the pdf say:
Score
kingzx87
February 6, 2012 5:27:19 AM
kingzx87
February 6, 2012 5:28:09 AM
DIMM failure when there is one DIMM present, no good memory
is present
Run-time memory uncorrectable error in non-redundant mode
IERR signal asserted
Processor 1 missing
Temperature (CPU ThermTrip, memory TempHi, critical
threshold crossed)
No power good – power fault
Processor configuration error (for example, processor stepping
mismatch)
is present
Processor 1 missing
threshold crossed)
mismatch)
Score
kingzx87
February 6, 2012 5:30:36 AM
page 60 . Led B
http://download.intel.com/support/motherboards/server/s...
Score
kingzx87
February 6, 2012 5:33:03 AM
kingzx87
February 6, 2012 5:35:49 AM
kingzx87
February 6, 2012 5:39:45 AM
kingzx87
February 6, 2012 5:45:08 AM
kingzx87
February 6, 2012 5:47:07 AM
kingzx87
February 6, 2012 5:50:21 AM
Here's a little something from here at Tom's itself....
"1. CPUs must have the same QPI and RAM speed to work together.
2. CPUs must have the same thermal profile (TDP) to work together.
3. The CPUs must have the same number of physical cores to work together.
4. The CPUs must have the same number of logical cores to work together.
5. Stepping does not matter.
6. Clock speed does not matter.
If all of those are met, then you can run the CPUs together. The CPUs run at the speed of the slowest CPU. The current mix and match list:
1. Xeon E5502- can only work with another E5502 since it's the only dual-core Xeon 5500 (#4.)
2. Xeon E5504 can work with the E5506, both CPUs run at 2.00 GHz.
3. Xeon E5520 can work with the E5530 or E5540, both CPUs run at 2.26 GHz in either case.
4. Xeon E5530 can work with the E5520 (CPUs run at 2.26 GHz) or E5540 (CPUs run at 2.40 GHz)
5. Xeon X5550 can work with the X5560 or X5570, both CPUs run at 2.67 GHz in either case.
6. Xeon X5560 can work with the X5550 (CPUs run at 2.67 GHz) or X5570 (CPUs run at 2.80 GHz)
7. Xeon W5580 can work with the W5590, both CPUs run at 3.20 GHz)
8. Xeon L5506- can only work with other L5506s since it's the only L-series Xeon 5500 without HyperThreading.
9. Xeon L5518 can work with the L5520 or L5530, both CPUs run at 2.13 GHz in either case.
10. Xeon L5520 can work with the L5518 (CPUs run at 2.13 GHz) or L5530 (CPUs run at 2.26 GHz.)
11. Xeon L5508- can only work with other L5508s since it's the only 38-watt TDP Xeon 5500. "
Score
kingzx87
February 6, 2012 6:04:57 AM
kingzx87
February 6, 2012 6:11:46 AM
You need to check this
http://www.intel.com/support/motherboards/server/sb/CS-...
Is the BIOS of that board up to date?
What version is on it?
Does it support the E52XX Processors, since Intel is being very specific about it's 52XX Line
"Intel® Xeon® processors 5400 and 5200 series require specific hardware and software revisions on the following Intel® Server Boards and Platforms:"
Score
kingzx87
February 6, 2012 6:17:16 AM
yeah, i understand that....
I'm trying to figure that out...
Do you have an old processor on you that might have been in the rig?
Have you tried to Clear the BIOS and start from scratch, but, this time, make sure you are using the bare minimums, only, one processor in Slot 1 the second slot should be empty.
The four RAMs in the slots I specified earlier.
Etc etc
Please read this:
Try to install each CPU in single mode operation and see if both of them works.
The board supports one or two Intel (R) Xeon Processors 5000 sequence.
Not all boards or systems support the Intel® Xeon® Processors 5400 and 5200 processors. Refer to Support for Intel® Xeon® Processors 5400 and 5200 to ensure you order the correct product.
If you are using a non-refresh board, then any 45nm CPU is not meant to be officially supported on the non-refresh board.
If your board is a non-refresh board, then only 65 nm cpu worked fine on it.
A non-refresh board will not have a letter 'R' at the end of the naming.
Example: S5000XVNSAS, S5000XVNSATA
A refresh board will have the letter 'R'
Example: S5000XVNSASR, S5000XVNSATAR
Now regarding the population for the CPU, refer to the document
Section 3.1.2.1
Page 24/112
Etc etc
Please read this:
Section 3.1.2.1
Page 24/112
Score
kingzx87
February 6, 2012 6:28:10 AM
Try the Intel Server Config Tool
http://serverconfigurator2.intel.com/compare.aspx?Categ...
Score
kingzx87
February 6, 2012 6:35:22 AM
kingzx87
February 6, 2012 6:36:23 AM
kingzx87
February 6, 2012 6:42:03 AM
Best solution
kingzx87
February 6, 2012 7:12:20 AM
- 1 / 2
- 2
- Newest
- ASUS P7P55D-E LX LGA 1156 Intel P55 Power Fan Connector Forum
- Moving from AMD to Intel-4 Pin to 8 Pin Power Connector Forum
- SolvedPower connector for evga 750ti Forum
- SolvedWhat power connector? Forum
- SolvedMy monitor wont receive a signal from my graphics card but does from mobo vga connector. Forum
- SolvedPower Supply -> 10-Pin connector, what is it used for? Forum
- SolvedAsus GTX 780 Power Connector Forum
- Solved780ti power connector Forum
- SolvedDoes a ZOTAC ZT-70601-10M 750 Ti GPU need a 6 pin power connector? Forum
- Solveddoes gtx 750 need extra power connector ? Forum
- Solvedhow to power a psu without a power connector...how to make a make shift one Forum
- SolvedInstalled a new motherboard and CPU, now I get power, but no signal on monitors and not reaching BIOS. Forum
- SolvedCPU 12v power connector/Mobo having 2 12v connector Forum
- SolvedDoes it matter what 8 pin i use for my CPU power connector? Forum
- SolvedCM Storm Stryker with No Mobo Power Connector Forum
- More resources
Read discussions in other Components categories
