Help me choose a motherboard
Hello.. I'm building a gaming pc and my budget is 1000$ .
I've chosen all the other parts but still I can't decide what motherboard should I [ick.. here are the candidates :P
1-MSI Z77A-GD65 LGA 1155 Intel Z77 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813130643&Tpk=MSI%20Z77A-GD65
2-MSI Z77 MPOWER LGA 1155 Intel Z77 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813130660&Tpk=MSI%20Z77%20MPOWER%20LGA%201155%20Intel%20Z77
3-ASUS P8Z77-V PRO LGA 1155 Intel Z77 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131819
I want it to be good at overclocking and has decent futures for gaming.. If you have other boards on mind that you think will suit me better tell me about :D
here's the rest of my build:
-CPU - Intel i5 3570k ivy 3.4 turbo 3.8
-GPU - SAPPHIRE Vapor-X 100352VXSR Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16
-Ram - CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866
-HDD - Western Digital WD Black WD1002FAEX 1TB 7200 RPM
-Case - Cooler Master HAF 912
-PSU - CORSAIR HX Series HX750 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
Also if you have other suggestions to my whole build please tell me thanks <3
Edit: I will be buying from newegg/Amazon
2 answers Last reply
More about help choose motherboard
  1. no thoughts?
  2. I can only speak to your 1st link. I have that Mobo in 2 i7 builds. I have not had any problems with either board. The UEFI Bios is easy to use. I have not overclocked but you can do it through the Bios
Motherboards Product
