my current setup is:
geforce 9600 gt
amd phenom 2 965 not oc
800 4 gb memory
asus crosshair II formula mobo
1 dvd
2 hdd: 1 TB and a 160 gb
1 80 mm fan
power supply, thermaltake 600w 80% efficient two lines v1 18 amp and v2 18 amp
More specifically: http://thermaltakeusa.com/Product.aspx?C=1432&ID=1527 # Tab1
my question is if I need to change my power supply on the other because I'm changing my video card to this 560 ti geforce
this: http://www.msi.com/product/vga/N560GTX-Ti-Twin-Frozr-II-OC.html
basically I'm not sure if it will be enough my power supply or if it just. I'm not using SLI or overclocking settings as you see my add in the future 2 80 mm fans
the other question is:
assuming enough my power supply.
There are 2 lines 12v of 18 amp each and am not sure if I connect 2 or only 1 to the video card. if I can clarify this thanks.
pardon my English.
geforce 9600 gt
800 4 gb memory
1 dvd
1 80 mm fan
pardon my English.
