Hello,
I tried to get my DS to go wireless, but it required a WEP key. I tried to switch it back to a WPA2 setting and now I'm unable to connect wirelessly. Also the other settings do not work as well. What can I do to fix this problem?
WEP has tended to be the generic term for a wireless security key, despite being the least desireable security level to use. You need to set your router to WPA for the DS to be able to "see" and connect to it even though WPA2 would be better. Start with by setting a completely new key.
