I’ve been looking at using a Dell XPS 730 for my first PC build basically because I have a XPS 720 and the case has a similar outside design. I’ve posted a couple of message in the form and I know I can use it, but I need to be aware that the MOBO fit upside down and the case has limited air flow. Since this is my first build, it has got me thinking that maybe I need to use a more current case. So I’ve decide to ask the form for advice/suggestions based on what I’m looking for in a case below:
• Full size ATX Tower
• low noise
• external I/O panel with USB 3.0
• open front panel (no doors on the front)
• Flat top with no more than half the top air flow out take
I’m not using liquid cooling for the system.
I appreciate your help and patience with this first time builder.
sms1295
• low noise
sms1295
