I am looking at purchasing an Asrock Extreme 3 mobo for a build I am doing.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157330
I am installing a separate video card, a Radeon 7850 with HDMI out. I intend to hook it to a television via HDMI. I have read things saying that if your mobo has an HDMI out port then you can connect to the television via HDMI and get HDMI video and audio. Does this only work if you are using an onboard graphics option or does it work if you connect to the graphic card's HDMI also? I'm not real experienced with this but it seems as if, since the graphics card doesn't process sound, it wouldn't transmit audio to the TV.
