Hi,
Looking for some help on a new build, my old system died last weekend so I had to rebuild, wasn't really prepared for it so had to do things a bit on the cheap (it's only for basic home use).
The PC boots fine first time, I have run it for almost a whole week but after shut down, I need to turn off the switch on the power supply to get it to fire up again, otherwise it runs for about a second (long enough for the fans to spin up but nothing more), then dies for a few seconds, then tries to start again, and keeps repeating. I tried replacing the PSU as initially I used the old one so I thought that might be the problem (an old basic Thermaltake that came with the case) but it's still doing the same thing.
Specs as follows:
- MOBO: ASRock Z68M-USB3
- CPU: Intel i5 2500 (standard, no OC etc)
- RAM – 2x4GB G.Skill DDR3 1333
- 3 SATA HDD
- PSU: Antec Neo Eco 450C
- Winfast DTV 2000H TV Tuner
Thanks
Specs as follows:
- 3 SATA HDD
Thanks
