Final review of new i5 2500k system build, opinions please
Last response: in Systems
After several weeks of research, visits to forums etc. I have a system design and would like opinions. Also, most importantly... Have I forgotten anything? At some point I will overclock this thing, so I am wondering if I need an aftermarket cooler, if so any suggestions? Suggestions on nice to haves I haven't thought of?
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
GIGABYTE GA-Z68XP-UD3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
EVGA 01G-P3-1372-TR GeForce GTX 460 (Fermi)
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case
CORSAIR Builder Series CX500 V2 500W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
Already have keyboard, monitor etc.
Thanks,
CD
Thanks,
CD
More about : final review 2500k system build opinions
- g-unit1111 has closed this thread
Apparently I forgot about a hard drive... Any suggestions?
CD
Thanks,
CD
CD
celticdaddio said:
After several weeks of research, visits to forums etc. I have a system design and would like opinions. Also, most importantly... Have I forgotten anything? At some point I will overclock this thing, so I am wondering if I need an aftermarket cooler, if so any suggestions? Suggestions on nice to haves I haven't thought of?Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
Thanks,
CD
Hard drive prices are up since the flood in thailand so you will be paying 3 times the worth of 1 HDD now no matter where you buy it so I'd wait untill hard drive prices go down again.
If you decide to build it now then go with a Samsung Spinpoint F3 1TB
It's a good looking build all around and should get you some decent performence in gaming.
Related ressources
- Please help with new 2500k build ... - Forum
- Please Review Final Build on High End Rig - Forum
- I5 2500k , compatibility and performance of new build , please comment - Forum
- Final Build : i5 gaming ( review and check) - Forum
- Final Build Before Purchase - Please Help Review - Forum
Mastervivi10 said:
Hard drive prices are up since the flood in thailand so you will be paying 3 times the worth of 1 HDD now no matter where you buy it so I'd wait untill hard drive prices go down again.If you decide to build it now then go with a Samsung Spinpoint F3 1TB
+1 for the spinpoint f3, though the prices are through the roof because of the flooding, but if you need a HDD now then your just going to have to buy one as prices arnt set to come back down untill some time next year.
You should really buy an aftermarket cpu cooler too.
If money is no problem then go for this, its a beast
or if you are on a budget then this is the best "bang for ya buck" cpu cooler
I would also recomend spending a bit more money on a better PSU, something like this
Don't know why my link isnt showing up in my sig but here you go
http://www.pcityourself.com/index.php
Its animated and will walk you through step by step cant remember who I grabbed this from it was too good to pass.
Have you ever considered a GTX 560 or it don't fit ur budget?
Like this one:
EVGA 01G-P3-1460-KR GeForce GTX 560 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://204.14.213.185/Product/Product.aspx?Item=N82E168...
It have a better performance/wattage ratio and it's faster than the GTX 460, and if u go for SLI path in the future it will be much easier to find a GTX 560.
Consider too another PSU if u planing to SLI ur system, or u will need to buy another one.
Like this one:
Emelth said:
Or he can get 2x460s which will out do a 560 TiIf he gonna get 2x460s he will need to change the PSU too.
Ah! Btw, I do have 2x460s (Stock), and by some benchmarks in Tomshardware, Anandtech, Guru3d and others I saw that the performance is much higher than the 560 Ti, if scaling properly with the software it reach levels of GTX 480 to a bit higher GTX 580 depending of the game.
Thanks, that looks cool.
CD
CD
Emelth said:
Don't know why my link isnt showing up in my sig but here you gohttp://www.pcityourself.com/index.php
Emelth, couldn't pass this up from your link on PC assembly.
The only essentials you will need the before starting are:
A phillips screwdriver
A grounded metallic object
A large flat non-metallic surface (1.5m x 1m or larger)
An afternoon of uninterupted time
You you may also want:
An anti-static wrist band or mat
Cable ties
A small torch----->flashlight
Some plasters (for little cuts you may get)----->Band Aids.
I can just see some noob unfamiliar with the King's english going to the hardware store
looking for one of those butane torches used for brazing jewelry etc. and some special computer plaster.
Cable ties
I hadn't thought about the 580... the 460 fits in my budget much better... and to be honest, I have somewhat tried to keep from thinking along the lines of "this one is better for a few dollars more" because at first I did that on alot of the components and ended up with system that cost almost 2x my budget...
However, my main application is writing OpenGL simluation/CUDA code so maybe I should look at the 580. If I go with the 580, is a 650W PS good enough?
CD
Like this one:
CD
vitornob said:
Have you ever considered a GTX 560 or it don't fit ur budget?Like this one:
Related ressources:
- Forumi5 2500k build ( opinions , please )
- ForumFinally about to build my custom PC! Final Opinions ?
- ForumHomebuild Gaming System Advice and Opinions
- ForumFinal First Gaming Build - Please Review !
- ForumHelp with new build !!! i5 2500k $1500 or under
- ForumI5 2500k BF3 build
- ForumHTPC Mobo+CPU ~$150
- More resources
