8-pin EPS12V PSU with a 4-pin ATX12V Mobo - Need help
  • Gigabyte
  • Motherboards
  • Corsair
  • Product
December 8, 2012 12:38:00 PM
Hi there,
So I'm facing a dilemma at this moment in time - can 8-pin EPS12V CPU power connectors be plugged into 4-pin ATX12V with the remaining four pins left hanging over? The reason I ask is because I would really like to get a modular Corsair PSU, the problem being that all of their modular PSUs have this 8-pin connector but my motherboard only supports the ATX12V kind.
I'd greatly appreciate any help on this matter.
Further details: Corsair TX650M Modular PSU (the PSU in question), Gigabyte GA-Z77X-D3H motherboard.
Thank you in advance :)
More about : pin eps12v psu pin atx12v mobo
a b V Motherboard
December 8, 2012 12:54:48 PM
Usually 8 pin connectors are split into 2x4 pin connectors. Put one of the 4 pin connectors in your jack with the latch facing the right way. Just leave the other 4 pin connector hanging loose. No problem.
December 8, 2012 8:43:35 PM
Ah thank you. Though I can't help but notice that some PSU specifications say "4+4 EPS" or "8-pin EPS12V connector with detachable 4-pin ATX12V", the TX650M only says "8-pin EPS".
a b V Motherboard
December 8, 2012 9:45:51 PM
Anyway, just to let you know, that motherboard uses a 8 pin EPS connector. So just plug both of the 4 pins together which equals an eight pin
December 8, 2012 10:51:13 PM
It doesn't, shadow_city. This is an exerpt from the specifications of the motherboard: Power Connectors 4-pin ATX12V connector, 24-pin main power connector
a b V Motherboard
December 9, 2012 1:25:53 AM
My bad, I looked at the revision 1.1 version, which has a 8 pin connector. The 1.0 revision has a 4 pin.
