Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > [Solved] Upgraded graphics card for HP Pavilion Special Addition a6755y
Forum Graphics & Displays : Graphics Cards [Solved] Upgraded graphics card for HP Pavilion Special Addition a6755y
Best answer from COLGeek.
:hello: Hello all-
I am not very computer-inclined, and I am trying to hook up my HP Pavilion Phoenix Special Edition a6755y to my new 32" Vizio HDTV. It's not working. I believe the issue is that my on-board graphics processor (chipset: AMD 780g, graphics: ATI Radeon HD 3200) isn't capable of handling the necessary 1920x1080 screen resolution.
I think my only option at this point is a new video/graphics card, but I don't know how to determine what is compatible with my system, and will support the 1920x1080 screen resolution.
Specs:
Motherboard: MS-7548 (Aspen)
Processor: Phenom X4 9550
Memory: 6 GB
Video graphics: Integrated graphics using ATI Radeon™ HD 3200 (Supports DirectX® 10)
Sound/Audio: Integrated Realtek ALC888S Audio
Networking: LAN: 10-Base-T, 802.11 Wireless a/b/g/n PCI-Express x1 card
Hard drive: 640 GB
CD/DVD disc drive: DVD+/-R/RW 16X 12X +/-DL LS 12X RAM SuperMulti SATA drive
Memory Card Reader: 15-in-1 multimedia card reader
Computer Case: Mid-size ATX
Power Supply: 300W
I/O Ports
Front I/O ports
Back I/O ports
Needs:
I do not play video games, or require anything fancy besides the following:
Compatible with system requirements
Display in 1920x1080 screen resolution
HDMI output
Budget:
As low as I can get away with :D
Thank you SO MUCH in advance. This is driving me bananas!! :heink:
Message edited by rokcandy3 on 09-07-2011 at 04:32:54 PM
Reply to rokcandy3
Your computer will definitely connect to your HDTV as long as you have the proper DVI to HDMI adapter or DVI to HDMI cable.
On the HDTV, you need to select the proper input device for it to display the image from the computer.
You do not need to buy a stand alone video card for your purposes.
Reply to COLGeek
I got it to connect, and finally got it to display, but not in the native resolution of the TV (1920x1080). Its connected via VGA... would the 1920x1080 resolution option be available if connecting by DVI to HDMI?
Reply to rokcandy3
While not optimal, you can certainly run 1920x1080 via the VGA connection. As you know, the digital (DVI/HDMI) connection is preferrable.
That being said, you may need to simply update your video drivers. Cruise on over to ati.com and then get the 32-bit or 64-bit (depending on what you are running) version of the 11.8 Catalyst Software Suite. Install and then restart and you should be able to change your resolution to the max supported by the HDTV.
Good luck!
32-bit:
http://sites.amd.com/us/game/downl [...] n7-32.aspx
64-bit:
http://sites.amd.com/us/game/downl [...] n7-64.aspx
You do not need to run the HP drivers, You can use these "generic" drivers.
Reply to COLGeek
Good luck!
32-bit:
64-bit:
First off, thank you SO MUCH for helping me. I'm feeling quite inept.
Tried the new driver thing, here's what happened (or happening, currently re-do-ing this process):
Catalyst 11.8 (64-bit, from the ATI website):
Installs, reboots, but nothing changes.
Computer>preferences>device manager>display adapters>ATI... still says version 8.881, and that the version was published 7/28/2011, when I click UPdate driver> search the internet it DOWNgrades me to 8.7 and I have to rollback to 8.881. When I try to search computer (specifying folder AMD>catalyst 11.8) it says it it up to date.
Display settings>advanced>AMD VISION Engine gives me option to open Vision Engine, but it doesn't open
No option for Catalyst anywhere, except to re-install from the download
Also tried starting with version 9.1 (next specified after 8.7-- since ATI doesn't show 8.881 anywhere):
Installs, but cant find any record of it that is recognized by the driver update system.
Do I just not know how to install drivers correctly? What am I doing wrong? I feel like I've tried everything (which means it's the one thing I haven't tried, right? haha)
Reply to rokcandy3
OK, sounds like you have a couple of things here. Don't do the driver update thing via Device Manager. That will install a Windows "stock" driver and not the current ATI/AMD driver.
Go here for info regarding what you installed:
http://support.amd.com/us/kbarticl [...] Notes.aspx
Is your Win 7 installation fully up to date?
Reply to COLGeek
Its Vista 64 bit, and yes, it is fully up to date. Just got off the phone with AMD and they can't tell me whats going on, except that the integrated graphics SHOULD be able to display 1920x1080 but they don't. He was also baffled that I didn't have an HDMI out, and had no idea if DVI to HDMI would fix the problem at all. He suggested I get a new graphics card, but he's not sure if the ones he suggested will work with my power supply. Totally useless...
Reply to rokcandy3
Understood on tech support, really not a question they can answer......
Vista 64 uses the same driver at Win 7 64.
Go here and download and install Driver Sweeper. Run the tool to completely remove all ATI drivers. Restart your rig and re-install 11.8. See if that helps.
http://www.guru3d.com/category/driversweeper/
Reply to COLGeek
Will do. Again, I can't thank you enough. The tech support guy said it might just be an issue of vga vs dvi/hdmi. Supposedly version 8.881 is the newest driver for the graphics card, which I guess is different from catalyst? I've completely confused myself at this point. I will try your suggestions as soon as I get home. You rock for all your help, man. Seriously.
Reply to rokcandy3
Catalyst is a tool that lets you manage the video card and includes the driver and a couple of other utilities. At the same site you got the file from, you can also download a driver only version (without Catalyst).
BTW, you are most welcome. We'll get you sorted out. Good luck!
Reply to COLGeek
So... after all that, the problem was the VGA vs HDMI issue. I guess since VGA is analog, it couldn't support 1920x1080. After buying a DVI to HDMI and hooking it up, all it took was a restart and the correct resolution popped up.
This was absolutely exhausting for me. I don't have a "computer brain" at all.
I CANT THANK YOU ENOUGH FOR HELPING ME!! There is no way I would have gotten through this without your help. I would have given up!! You're definitely my hero... I wish I could give you a hug!! You're the best, COLGeek, whoever you are ;)
Reply to rokcandy3
Best answer
You are most welcome. Glad you got everything up and running as desired. You did good!
Reply to COLGeek
nice work COLGeek
+10
rokcandy3
Since you feel COLGeek did a great job
there should be an option to select one of COL answers as Best Answer
on the bottom of one of the answers
It is the Toms Hardware version of a hug LOL
------------------------------ "I yam what I yam and thats all that I yam"-Popeye-greatest 20th century philosopher
[http://valid.canardpc.com/cache/banner/2375043.png
Reply to king smp
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1949 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Graphics Card Help for a Casual
By geofelt, 1 hour ago:
As a standard, a pci-e x16 graphics card slot can deliver up to 75w to a graphics card...
Best offers
Top experts
