Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > [Solved] 6870CF vs 6950 Power Consumption
Forum CPU & Components : Power Supplies, Cases & Mods [Solved] 6870CF vs 6950 Power Consumption
Best answer from davcon.
I'm building a new system, and I have a Corsair HX-650W PSU, My question is I'll be keeping this PSU, and I was wondering if it could power 6870's in CF with a 2500k OC'd to 4.5GHZ, with a 1.35vcore. I will not be able to upgrade this PSU. I am hoping to go with the CF, but I don't want to blow up my PSU. Or should I jsut go with a 6950 OC it and possible Flash it to a 6970 bios. I don't think I would be able to do any OC with a 650 for 2 6870 in CF.
Reply to Vasquejj
Either way you'll be fine with your current psu.
Total power consumption for 2 x 6870 in full stress is about 420W.
Which leaves you over 200W for other components.
Message edited by davcon on 02-05-2012 at 04:12:54 AM
Reply to davcon
2 6870s on a 650W would be close to the limit. The video cards alone could draw ~425W, the overclocked 2500K another 150, drives, motherboard, fans etc. another 50W. That gives you a max wattage of 624 (erring on the side of caution) which I would feel is a bit close to the limit but still safe. The risk of early PSU failure due to running close to the limit would probably be higher but if you have good airflow in your case, you'd probably be safe. The 6870s would far outperform the 6950/70 (I've got 2 6870s and love them except when amd is slow getting drivers out) so if I were in your position I'd take the 6870s simply because that's a high quality PSU with 4 PCIe connectors, I wouldn't trust most other PSUs.
Out of curiosity, would you no be able to sell the 650W in order to subsidise the purchase of a more potent unit?
6870 XFire review - http://www.guru3d.com/article/rade [...] x-review/4
2400K power draw - http://www.hardocp.com/article/201 [...] s_review/6
6970 power draw - http://www.anandtech.com/show/4061 [...] hd-6950/24
Sorry for the essay but I'm curious if anyone else has a different take on this.
Message edited by DodSno on 02-05-2012 at 04:56:54 AM
Reply to DodSno
Best answer
Guru3D
"Our test system is based on a power hungry Core i7 965 / X58 based. This setup is overclocked to 3.75 GHz. Next to that we have energy saving functions disabled for this motherboard and processor (to ensure consistent benchmark results). On average we are using roughly 50 to 100 Watts more than a standard PC due to higher CPU clock settings, cooling, additional cold cathode lights etc."
"With that in mind. Our normal system power consumption is higher than your average system."
The OP's HX-650 will be fine for a SB build o'cd with 2 x 6870.
Message quoted 1 times
Message edited by davcon on 02-05-2012 at 05:03:41 AM
Reply to davcon
davcon wrote :
Guru3D
Good point, that puts peak power closer to 500-550W depending on the rest of the system and well within safe draw (sometimes I read too fast :??: )
Reply to DodSno
Agree with davcon here.
I use the power estimates from
http://forums.atomicmpc.com.au/index.php?showtopic=264
They are based on manufacturer's data and tend to overestimate power usage a little which makes them a great "worst case" estimate.
I estimate power consumption of an OC'd CPU as TDP + 25%. This is pretty close to actual measurements.
Motherboard and RAM: 80 - 120 watts depending.
Two hard drives and an optical: 40 watts.
This gives me an estimate that is about 10 - 15% higher than what I measure with my Kill-A-Watt meter. I call that Mr. Murphy's share (ignore Mr. Murphy at your peril :)).
So I would estimate power consumption:
Two 6870's: 20 amps peaking to 25.
CPU: 10 amps.
That is about 360 watts. (Inexpensive power meters do not respond to short duty cycle peaks - Mr. Murphy again.) Add another 160 watts = 500 watts.
Subtracting 10% puts us close to what Guru3D measured (421 watts).
Reply to jsc
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1954 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 4 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
