Hello, Ok so here is the problem
when I install my second memory module it beeps over and over and then shuts off and turns back on and then does it all over again. I have checked both ram in the first slot and they both work but as soon as I add the second one it doesn't. I am using a gigabyte z77-DS3H motherboard. Could my motherboard be bad, I thought I would check on here before I sent anything back
