Solved
Is the memory ok with this motherboard? (model doesn't match exactly)
Hi Guys,
I'm building a new system, and want to use this memory:
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory Model F3-17000CL9D-8GBXM
with this motherboard:
ASRock Z68 PROFESSIONAL GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Here is the motherboard's compatible memory list:
http://www.asrock.com/mb/memory.asp?Model=Fatal1ty%20Z68%20Professional%20Gen3
I'm confused - the model is like 80% correct, but the last trailer seems different.... I can't find any model that exactly matches. Can anyone help?
Thanks!
Timothy
6 answers Last reply Best Answer
More about memory motherboard model doesn match exactly
  1. NO, Sandy bridge requires 1.5v or lower ram
  2. Best answer
  3. abekl said:
    hmmm, alright, thanks guys. where could I have looked to have known that? Also, neither of those two shows up in the list on the mobo page:
    Do you know why that is?
  4. "where could I have looked to have known that?"
    If it's not stated in the MB manual, then it comes down to general knowledge of the Sandy Bridge platform.
    "neither of those two shows up in the list on the mobo page"
    The manufacturer can't test every piece of RAM out there.
  5. Best answer selected by solitas.
  6. Alright, thanks very much. :)
New Build Motherboards Memory Systems Product
