I'm currently in need of 4 new 120mm fans. I need 2 to replace the front 2 that came with the case, and I'd like to get 2 more for the extra slots for my case (side and other HD bay).
I'm a little new to adding extra fans like this so I have a couple questions in mind.
1) With the components below, would I really be able to put a fan in the case's 2nd HD bay fan slot? Either in front of the CPU or in front of the Video Card.
2) What fans should I go after? The current fans in the front have power connectors that attach to the molex power plugs that would feed the normal components (IE: molex Rom Drives/HDDs).
It looks like the motherboard I'm getting can support 3pin power fans (up to 4), but looking at a few options, I'm not seeing anything that makes me believe the power cords will stretch from the front of the case to proper places on the motherboard.
Personally, I'd be happy with power connectors similar to that the ones in place already have, but I'm not finding those anywhere.
Case
http://www.antec.com/Believe_it/product.php?id=MjM=
Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130574
Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130651
CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106150
Case
Motherboard
Video Card
CPU Cooler
