Fans controlling & monitoring
  • Power Supplies
  • Components
Last response: in Components
February 5, 2012 9:57:50 PM
hi
where to tell if my fans get monitored or controlled by the MOBO?
More about : fans controlling monitoring
a b ) Power supply
February 5, 2012 10:29:56 PM
check your motherboard user manual for the one monitored usualy the cpu fan is ,but all the one connected to the board are monitored
February 6, 2012 11:47:30 AM
Nowadays current mobo's use software provided in the installation CD, I would take a quick search on the mobo brand and downloads for the mobo see if there is any fan controlling software, other than that its likely in the bios/
February 6, 2012 2:12:27 PM
hi
thx for all the replies
thx for the programs
is it also posibale by the BIOS?
a c 158 ) Power supply
February 6, 2012 2:16:45 PM
You can typically monitor status of your hardware from the BIOS. To determine whether or not you can control your fans from BIOS you would need to check your motherboards manual.
If you want to be able to increase/decrease fan speeds manually, then there are a lot of fan controllers available on the market.
February 6, 2012 7:15:23 PM
ok
thx for your answers, very helpful
