Need advise on a gaming computer's parts.
Hello, I'm looking to build a Gaming PC with a budget up to $1000 USD. And I'm looking for some advice about the parts I've chosen.
[Obligatory Build Help Form]
Approximate Purchase Date: Within a month or two.
Budget Range: Up to $1000 After Rebates (Not Including the stuff I already have.)
System Usage from Most to Least Important: Gaming, Software Development
Parts Not Required: Keyboard, Mouse, Monitor, Speakers, OS, Case, DVD Drive
Preferred Website(s) for Parts: newegg.com (but i'm not against others)
Country of Origin: United States
Overclocking: Maybe
SLI or Crossfire: Maybe
Monitor Resolution: 1920x1080
[Current Parts List]
Monitor: ASUS VH236H (Currently Owned)
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236059
Case: Cooler Master Haf 922 (Currently Owned)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
Motherboard: ASUS M5A99X EVO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131754
Proccessor: AMD Phenom II X4 965
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
Video Card: ASUS ENGTX460
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121391
Ram: 16GB G.Skill Ripjaws
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231312
DVD Drive: LITE-ON 24X DVD Writer (Currently Owned)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
HDD: SAMSUNG Spinpoint F3 HD103SJ
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
So like I said, I'm asking for advise about the things I've chosen. Are these good choices? Are thy compatible?
I'm particularly wondering if the Video Card and the Motherboard are compatible. Also with all of these, what
power supply would you recommend? Also I would appreciate any extra parts recommendations.
4 answers Last reply
More about need advise gaming computer parts
  1. Downgrade to 8GB of RAM and get a GTX 560 Ti
  2. Thanks for the advise, though do you have any particular reason why?
  3. Yes,.....
    -16GB will do nothing for you that 8GB won't do unless you thinking workstation apps, photo or video editing.
    - the 560 Ti will shortly be 2 generations old
    - Also, I can't make a case for AMD CPU's in a build above $800.
    -Two of these 750 GB HD's are same price as the selected 1TB
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148789
  4. +1 to the above advise
Homebuilt Gaming Systems Product
