RAM problem need help fast!
So, i'm going to upgrade my computer with new motherboard, and i'm not sure if my RAM sticks will fit in my new motherboard. So i got now 8GB DDR3 RAM, and the thing is... I got ASUS Essentio CM6730 computer and have some "ASint" branded RAM, and i can't find it on any computer part shop or anything else, so can it be like HP branded RAM, and can those brand RAM's fit in any motherboards or can those fit only with their own manufacturers motherboards? Please help! Should i buy new RAM or can i keep those RAM sticks, and be sure that those will fit in my new motherboard?
And btw this will be my motherboard: http://www.gigabyte.com/products/product-page.aspx?pid=4153#ov
1 answer Last reply
More about problem fast
  1. Hi You can install the memory and test. I they worked with the H61 board, they should be fine with the new one too.
Memory RAM Motherboards Computer
