So I just ordered a SAMSUNG 830 Series 2.5-Inch 512GB SATA III for my PC which has a Sabertooth X58 motherboard, that a month or two ago I upgraded the BIOS to 1402 with no problems. Its running a dual boot windows 7 pro / windows 8 pro each on a separate HDD (sata 6GB velociraptor HDs) on the sata 6 GB connectors on the motherboard. I'm wanting to replace the windows 8 HDD with my SSD and do a clean install of Win 8 pro to dual boot alongside my old win7 pro HDD installation.
Right now everything is running fine, no problems. But I've never installed an SSD before and understand there may be som BIOS settings that need to be changed (like AHCI) but I don't run any RAID configurations. So I would appreciate any advice on how you got yours installed and working fine (up until now of course).
So now I have a couple questions that might be the answers to your problem. Is your SSD in a Raid configuration? Did you experience any problems running this SSD before on the sata III 6GB connectors?
The reason I ask is this: I'm thinking of returning my SSD as soon as it comes in because of what I've found doing extensive reading of message boards.
They say that the Marvell controllers for the 6GB connnectors specifically are garbage, and cause all kinds of problems for people running or booting their SSDs (granted not all were our Samsung 830 series). They also say that the motherboard connectors are limited--specifically cap your SSD throughput read and write times at like 390-400mb/s, thus not fully utilizing the speed of your SSD. Also, most of these posts are all from 2010-2011. So I'm trying to figure out if the BIOS updates since then have fixed this issue, or if this may be your/become my problem.
TehNevs said:
I am having a strange issue with my Asus Sabertooth x58. It's actually two different problems:
1.) I recently upgraded the BIOS to the latest version (Sabertooth X58 BIOS 1402) having never upgraded the BIOS on this machine before in 3 years. Everything ran smoothly. However, now whenever I boot up my machine, the system will start, then stop, and will do this exactly 2 times before starting up permanently. Also, my usb 3.0 ports (2 of them) on the back of the motherboard seem to not be working. Whenever I hook up a USB device to it, it does not show up on my Windows 7 installation.
2.) Sometimes my SSD will not boot. I have a "SAMSUNG 830 Series 2.5-Inch 256GB SATA III" model. I go into the BIOS and see that my boot order has been reset. It seems to do this at random and I am not sure why. Also, I sometimes have to switch between IDE and AHCI in order to get it to work. Sometimes the SSD will boot on IDE and sometimes it will boot in AHCI.
Let me know if there's any other information I can provide to help solve this problem! Thanks
