PC is not running when i plugged the 4-PIN cpu power connector !!!!
  • Asus
  • CPUs
  • Power
  • Motherboards
December 10, 2012 6:07:32 AM
please someone help me with this problem...
when i run the pc without 4pin cpu connector, its worked but no display in monitor...
after plugged the 4pin cpu power connector, smps,hdd,cpu,cpu fan,dvd drive etc.. not working/running..!!!
someone help me plzzzzzzzzzzz
sorry for bad english..
my PC's specs:-
MOBO-ASUS P5KPL-AM IN
CPU-INTEL PENTIUM 4® (cpu working in another mobo)..
RAM-1GB DDR-2
No gfx card
.... PLZ help me plzzz
More about : running plugged pin cpu power connector
December 10, 2012 6:29:29 AM
Rply plz if u know to fix this problem...:( ...plz help me..!!
m
l
December 10, 2012 4:36:45 PM
Check the manufacturer's website to see if you have the latest bios for your board. However, the most likely culprit is your power supply or motherboard. If there is a bad trace in the copper on the motherboard, this might happen. I would first try using another power supply if you can get your hands on one. If not, take it into a computer repair shop and have them test your power supply after you explain exactly what has happened so they are sure to test the right cables on your PSU.
Good luck.
m
l
a b Ĉ ASUS
a c 160 à CPUs
a c 233 V Motherboard
December 10, 2012 4:55:00 PM
What make/model of power supply (SMPS) are you using? This does sound like a defective power supply.
m
l
a c 110 Ĉ ASUS
a c 179 à CPUs
a c 578 V Motherboard
December 10, 2012 5:01:06 PM
What do you mean " when i run the pc without 4pin cpu connector, its worked but no display in monitor...
after plugged the 4pin cpu power connector, smps,hdd,cpu,cpu fan,dvd drive etc.. not working/running..!!! " ?
Do you use the right PSU connector?
m
l
December 11, 2012 12:54:24 AM
thnx everyone for reply...
@ COLGeek- My PSU's name is- "ATX P4 POWER SUPPLY JIL-2410 (with 20+4 pin)"...and yes when i turn on pc with cpu power connector, i heared a sparking sound from psu!......
@cin19-yes...
m
l
December 11, 2012 1:30:18 AM
@cin19-yes...
A sparking sound in the PSU sounds like a pretty dead give away. Maybe you should have mentioned that first. lol Go get a better power supply. I don't think you should be hearing any sparking sounds coming from any PSU.
m
l
a b Ĉ ASUS
a c 160 à CPUs
December 11, 2012 1:39:51 AM
Did you connect the +4 connector (part of the 20+4) into the 4-pin socket? If so, that is the wrong connection.
m
l
December 11, 2012 8:17:24 AM
ya..i connect all 24 (20+4) pins...
m
l
December 11, 2012 8:19:04 AM
no i didnt connect the +4 pin into cpu power connector shocket..
m
l
a b Ĉ ASUS
a c 160 à CPUs
December 11, 2012 9:37:39 AM
Swap PSUs with another system if you can. Report back with the results. Good luck.
m
l
December 11, 2012 1:13:31 PM
i have try my psu with another mobo and its worked fine with 4pin power connector!!! and i try with another psu but my mobo didnt turn on when 4pin power connector plugged in!! :'( ...plz help me Mr.COLGeek!!
m
l
a b Ĉ ASUS
a c 160 à CPUs
April 12, 2013 9:38:24 PM
Okay, lets try this again. You have 2 connections to make on this motherboard. A 4-pin connection, near the CPU and a 20+4 (or 24-pin) connection near the IDE connection. Are both firmly attached to the connections from the power supply?
m
l
a b Ĉ ASUS
a c 160 à CPUs
April 12, 2013 9:42:18 PM
If you have a known good PSU properly connected and it still fails to work, then the motherboard is likely defective. If that is the case, there is no feasible way for the OP to fix the motherboard other than replacing it or returning to Asus for exchange/repair.
m
l
