My final set up need a bit of help
ok so hear what im geting on black friday so yah i got 15 day's to chose what i want hear's what i think will do pls bear with me the's is my fierst build >.>
core i5 2500k (will over clook to 4.5 mype more if i can get 5Ghz staple like my friend i helped him building so yah he can get 5ghz staple but the temps are so F high like 7x C O_O) on water cool
MOBO(Gigabyte Z68X-UD7-B3) is epic ;) mype a better asus MOBO same or cheaper price like Maximus IV Extreme-Z
case HAF x or ccrosair 800d ?
psu(1200W crosair i think it is 1204w) lol 4 XD or antec 1200w
storage (500GB) and ill get 3tb L8ter
and some fans one for the top of the case (red led)
4 fans for push/pull set up(red led) some rads comes with 2 fans 3 fans so ill only use like 3 or 2 so yah
4x2 gb ram=8 vengance 1600 Mhz
NZXT SENTRY 2 fan con
BF3 :sol:
and a water cooling kit wich IDK what to pick duh coz my friend get 70C wich is to high for water cool i think
will ill be happy below 60 will playing BF3 at ultra
so yah ill use the water cool to cool the cpu only F K cpu allways hot thats not anything new -_-''
ill water cool the GPU L8ter if hit 70C will playing
srry for bad ENG
5 answers Last reply
More about final help
  1. If this review is any measure, the older UD7 didn't stand up well to the competition from Asus .....
    The 590 is a dog. Twin 56 Ti's will give ya about the same score for $300 less
    Guru3D uses the following games in their test suite, COD-MW, Bad Company 2, Dirt 2, Far Cry 2, Metro 2033, Dawn of Discovery, Crysis Warhead. Total fps (summing fps in each game @ 1920 x 1200) for the various options in parenthesis (single card / SL or CF) are tabulated below along with their cost in dollars per frame single card - CF or SLI:
    $ 215.00 560 Ti - 900 Mhz (495/862) $ 0.43 - $ 0.50
    $ 340.00 570 (524/873) $ 0.65 - $ 0.78
    $ 480.00 580 (616/953) $ 0.78 - $ 1.01
    $ 725.00 6990 (762/903) $ 0.95 - $ 1.61
    $ 750.00 590 (881/982) $ 0.85 - $ 1.53
    Case / PSU - Ya don't need 1200 watts for a single 590 and two of them in SLI is a waste for just 100 fps. If ya go with twin 560's or 570's, an 850 watter is fine.
    SSD - Suggest moving to a 550 MB[s 120/128 GB
    Case - $ 150 - Antec DF-85 or 1200V3
    PSU - $ 115 - Antec CP-850
    Sandy Bridge has no need for water cooling at 5 GHz
    It's almost ironic that [air] coolers like this are becoming available just as processors transition to designs that may ultimately render them unnecessary; even overclocked to 5GHz, an Intel Sandy Bridge 2600K doesn't need anywhere near this level of cooling.
    Make sure Vengeance is low profile toothy heat sinks.
    Think about a card reader .... sometimes combined witha Fan Controller
    Card Reader $ 50 55 in 1 Card Reader
  2. ok tyvm that evan save's my money ill be uploading pics after like 20days or so ill order evrything in black friday so yah i can get a tri sli but wich 560 the 2gb or 1gb tho the GTX 590 is dual and 3gb speed
    and wich air cooler should i pick
  3. ok after cheaking how much i can spent i can 2 way sli 570's and 3 way sli 560 ti and i can 2 way sli 560ti 2074MB so what is the best ? and difrence in the case is just the LED right ? but IDK when i 3 way sli the 560 ti wont i need a water cool wich i dont want to do XD coz takeing old thrmal paste and sh**t
    BTW ill buy all stuff from amazone so yah
  4. lol is it just me or the antec is so small? i think the HAF x is better but not cheaper?
    and i ment the ud7-B3 the UD7 sucks when i look at it i trhow up !
  5. i better but more info hear
    the pc is for gameing ill be useing soney playstion 24 inch 3D oh yah 3D
    i really want to reach 5GHz on my core i5 2500k
    i can go with tri SLI 560ti 1gb or 3 way 2gb and 2 way 570 also
    will i want a huge case like the haf x but if the crosair get cheaper in black friday ill buy it coz it got nice caple mng
    mother bord i cant dcide both same price and almost some on evrything but
    i need the one thats good for Over clooking and good on tri sli or 2 way sli
    psu 2 way 560 ti need 850 ? so 1000W should be over kill right?
    and will be good if some 1 ho have EXp on both mobo can help i dont want to start a mobo war so yah
    srry for bad eng agine
Homebuilt Systems Product
