Power supply does not turn off
  • Power Supplies
  • Shutdown
  • Components
Last response: in Components
February 6, 2012 9:59:44 PM
Hi,
I just assembled new computer and I have a problem with power supply: it does not turn off after a shutdown. Not even holding power button for a few seconds for hard shutdown doesn't help which suggest hardware problem and nothing to do with software :(
BIOS says all my temperatures are ok and everything else works. Also if I connect case fans directly to PSU, they don't stop working either.
I use Xilence 1000W power supply, CoolerMaster HAF 932 Advanced case and Asrock Z68 Extreme4 Gen3 mainboard.
Can plz anyone help with my problem.
Ty,
shumi12321
More about : power supply turn
a c 166 ) Power supply
February 7, 2012 1:33:18 AM
My first guess would be that either the front panel wiring is incorrect or the board is faulty.
a c 275 ) Power supply
February 7, 2012 3:01:23 AM
^+1 i agree!
