Hi, I'm building my first desktop and I'm running into a lot of problems. I've plugged in everything to the best of my ability and don't think the wiring is the problem, but I could be wrong.
My first problem is that when I turn on the computer, it shuts itself off in about 5-6 seconds and restarts itself. After that, it stays on just fine. Another issue is that there is no display on my monitor. I've tried plugging the monitor into the on board video from the motherboard as well and it does not work. Also, the light for DRAM LED RAM / MemOK is lit up for some reason and nothing else is besides the power and reset button.
The cpu fan, the gpu fan, and the case fans are all running. I do not have any spare parts to test whether or not something is not working. My gpu has been overclocked already right out of the box if that means anything. I wanted to try my luck on here before I bring it into the shop. Thanks.
Here are all of my parts:
Newegg:
EVGA SuperClocked 012-P3-1572-AR GeForce GTX 570
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130595
CORSAIR Enthusiast Series TX850 V2 850W ATX12V
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139022
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
ASUS 24X DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
COOLER MASTER HAF 922
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
Micro Center:
Core i5 2500K LGA 1155
http://www.microcenter.com/single_product_results.phtml?product_id=0354589
P8Z68-V PRO LGA 1155 Z68 ATX Intel Motherboard
http://www.microcenter.com/single_product_results.phtml?product_id=0364206
Barracuda 7200.12 1TB 7,200RPM SATA 6.0Gb/s 3.5" Internal Hard Drive
http://www.microcenter.com/single_product_results.phtml?product_id=0365152
Newegg:
ASUS 24X DVD Burner
Micro Center:
