*EDIT* This build takes into account the recommendations of many and personal preferences of those already in the thread. Also, I plan to use a 32inch HDTV as my monitor since it is laying around the house. Will this pose any issues with my build?
Budget Range: $1200 - 1600
System Usage from Most to Least Important: Gaming(World of Warcraft & Diablo 3), School Work
Parts Not Required: Keyboard, Mouse, And Monitor
Preferred Website(s) for Parts: newegg.com or tigerdirect.com
Country of Origin: US
Parts Preferences: I have always been an Intel chip fan. As for Motherboards, I prefer ASUS but I'm open to other brands. Graphics Card? I guess EVGA.
Overclocking: Possibly.
SLI or Crossfire: Possible in the future.
Monitor Resolution: Using a 32inc HDTV so I assume max at 1920x1080
Additional Comments: I would like the system to last for at least 3-5 years without needing to upgrade. The previous system I had was bought when quad core processors first came out and has done well up to now (~4years).
Processor: Intel i5 2500 Sandy Bridge: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
- $219.99
CPU Cooler: Hyper 212 EVO: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099&Tpk=212%20evo&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=1ghmxrmlbs0j8
-$34.99
Motherboard: Asus P8Z68-V Pro : http://www.newegg.com/Product/Product.aspx?Item=N82E16813131730
- $209.99
Memory: GSkill 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800): http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
- Seems decent and not expensive. $46.99
Graphics Card: EVGA GTX 580: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130587
- This is the 1.5Gb...is it worth 100 dollars extra for the 3GB?. $499.99
Hard Drive: OCZ 120GB SATA SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820227706
- HD are overpriced right now? $189.99
DVD Drive: ASUS 12X BD-R 2x BD-RE 16x DVD+R 12x DVDRAM 8x BD- ROM 8MB Cache SATA Blu-ray Burner: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135252
-I really don’t need a Blu-ray player but because I want it to last, I’d rather have it then be behind the times 3 years from now. $99.99
Case: Corsair Carbide Series 400R: http://www.newegg.com/Product/Product.aspx?Item=N82E16811139008&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=ds89jjvx6x17
- Roomy! $99.99.
PSU: CORSAIR Professional Series HX850 : http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
- In Case I SLI. $189.99
Total Expected price = $1591.91
Please comment as I plan to get this tomorrow due to black friday deals. Thanks!
- $219.99
-$34.99
- $209.99
- Roomy! $99.99.
