Will The Radeon Hd 6770 Fit In This HP Case?
  • Graphics Cards
  • Cases
  • HP Pavilion
  • Hewlett Packard
  • HD
  • Radeon
  • Graphics
  • Product
September 10, 2011 6:22:39 PM
Will the Radeon HD 6770 Fit In My Hp Pavilion 210f Case?
Video Card Information
HP Pavilion 210f Information
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?...
I have a 500w 50+B, I'm sure this is a good enough psu it's allready installed in my system. Information here
http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...
Thanks,
More about : radeon 6770 fit case
a c 214 U Graphics card
September 10, 2011 7:51:47 PM
Should be fine.
Just to be sure though measure 7 inches from the beginning of the expansion bay.
m
l
September 11, 2011 12:27:25 AM
purple stank said:
Should be fine.
Allright, thanks.
m
l
September 11, 2011 12:36:56 AM
Did it fit?
m
l
September 15, 2011 3:27:36 AM
purple stank said:
Did it fit?
I did some more research. I don’t want to order it and find out It won’t fit. I measured the dimensions and it looks like it may be a tight squeeze. I diced to go for something cheaper.
I think I will go for the 6750 (Info Below)
I'm not sure of this card, Hps dont have good vents. What do you think about it? Is it a smaller card?
m
l
September 15, 2011 3:39:48 AM
Should just go with a 6770.
You can always buy a better 120mm fan for the case.That alone should lower temps 10c.I know that HP case fans are that good.
m
l
