Bios Problems with agp card?????need help
September 10, 2011 8:27:23 PM
hi , my bois currently only says the maximum i can set for the graphic card's ram cache is 256 mb, if i get this card http://www.tigerdirect.com/applications/SearchTools/ite...
will it run, and if so, will the 1gb gddr3 still be used even though its not in the bios as an option. i really need help because im a newb at this (my dad's an expert im learning from him now). i just want to know if its is compatible and that it will run good and also tell me if it will use the rest of the 744 mb of gddr3 ram even if it's not recognized (most important)
More about : bios problems agp card
a b U Graphics card
September 10, 2011 9:44:05 PM
The option in BIOS is for the on board video. When you install that add in card you will get the full 1 gig video RAM.
m
l
