Yes No
Ads
Tom's Hardware > Forum > CPU & Components > DeepCool > Is This Liquid Cooling System Big Enough?
Forum CPU & Components : DeepCool Is This Liquid Cooling System Big Enough?
Hi Guys
Want to know if the cooling system I have in mind will be strong enough for hat I want to do.
The System I'm looking at buying is as follows
Power: Thermal-take Tough X-T 875-W
Video Card: ATI Radeon 6850 x2
Processor: Intel Core I7 2600
Case: Thermaltake Level 10 GT
MB: Ausus P8Z68-V Pro
_________________________________
Now the cooling system that I'm looking at getting for this system is also as follows
CPU Block: Koolance CPU-370 Nickel
Radiator: Hardware Labs black ice GT xtreme 240
Reservoir Pump: Koolance RP-1000B-K
Video Card: Koolance VID-A-R685
Now the products stated below have been selected because the Koolance selection wizard suggested them so that's what I think I'll be using
CHC-125-http://www.koolance.com/water-cooling/product_info.php?product_id=663
MVR-40-http://www.koolance.com/water-cooling/product_info.php?product_id=660
MVR-100-http://www.koolance.com/water-cooling/product_info.php?product_id=736
All to Be Done in 3/8" tubing
So as the title asks is this going to be big enough.
Please Help
Thanks
Message edited by joelsjet on 06-15-2011 at 08:43:57 AM
Reply to joelsjet
Moving to the watercooling forum.
------------------------------ Watercooling Info:
Tom's Hardware Watercooling Sticky
Build Log | Project: Askew
Stuff 4 Sale
Reply to rubix_1011
Couple questions:
Why all the Koolance gear?
Only a 240 (2x120mm) rad? You'll actually need about one of those per CPU and GPU.
No, no and no on the other 'suggested items'. (There is no reason/gain to watercooling voltage regulators, RAM, MOSFETS or even southbridge. There can be some argument made for northbridge...if you plan to overclock to very high speeds.)
There are other options; some less expensive. Are you dead-set on using only Koolance?
What is your budget? There isn't much difference between 3/8" and 1/2" tubing...any reason you chose 3/8" instead?
Message edited by rubix_1011 on 06-13-2011 at 10:06:32 PM
Stuff 4 Sale
Reply to rubix_1011
@ rubix ..what do you have against Koolance ?
@ OP,here are some questions;
-how much are you plan to OC CPU/GPU ?
-how important is the noise ?
-internal or external rad placement ?
-budget ?
the choice of your case is not the best for LC ,i own P67 platform..trust me you don't need to cool SB/MOSFET,but if you insist, you will need two pumps,single 240 won't cut it
P.S.good choice of CPU/GPU blocks
Reply to ortoklaz
Easy there, killer...same team. :)
I don't have anything against them...I just am curious why people choose all DangerDen, all Koolance, all Swiftech etc. instead of listing other components from other vendors. Koolance makes some pretty good gear...however, I would choose a different pump/res combo for less money, but that's just me. I like to hear validation why someone chooses block 'X' over block 'Y' simply to see if they have done their homework. Knowing why someone made the choice they have goes a long way into seeing their level of understanding or where they might need some help. Just an indirect tactic I use, nothing more.
OP doesn't need 2 pumps...but I won't say not to when he might have the budget.
Message edited by rubix_1011 on 06-14-2011 at 03:45:46 AM
Stuff 4 Sale
Reply to rubix_1011
rubix_1011 wrote :
Couple questions:
No reason for only Koolance just the best deal i could find so far.
Not on much of a budget but would rather keep it all under $2500 but if its more so be it.
And yes I want to over clock anything and everything i can as high as I can. Bit of a learning curve :ange:
As for the Tubing again no reason at all
Reply to joelsjet
-budget ?
Noise is something i would want to keep low but I'm more interested in the performance of over clocking.
Also I'm going to have headphones on most of the time.
Not sure about rad what do you think. was thinking about having extra rad in between CPU and video card for extra cooling. what do you think
No real budget
Over clocking to the max
Reply to joelsjet
Hey Joelsjet Im was looking over your cpu and I guess you left out the k in the 2600. I read were you wanted to oc your system so Just wanted to check you are getting the 2600k which is unlocked 2600 is not. Good luck man.
Reply to christop
Quote :
Loop order doesn't impact cooling. You could change the flow order and not see a difference between the setups. Just FYI. (if you do, you have a problem with your loop.)
Stuff 4 Sale
Reply to rubix_1011
Thanks christop I really did not realise this at all. I just went for the 2600 because it looks to have about the same specs as the 2600k but without such a price tag.
So What would be the best option, the 2600k or the i5 2500k what are your thoughts?
Anyway Thanks again would have wrecked everything.
Reply to joelsjet
rubix_1011 wrote :
Quote :
Ok But would you not get better cooling if you ran from your pump to the CPU then through a small rad then through the video card plus watever else I need for the mother board, back through the big rad to go to the pump.
I left out the resovior in the above system to simplify.
And on the subject of rads. So as far as i understand you can mount a rad where fans normally go. On the Thermaltake level 10 GT its designed to have a 240 rad at the top. But would it be possible to put a extra small one in where one of the fans are meant to be. Or would that cut of to much air flow
Thanks mate
Reply to joelsjet
Hey just quickly how do i put in hyper links if I want to show a product I found
Thanks
Reply to joelsjet
hey guys
just reposted in 'over clocking'-'water cooling' area
Reply to joelsjet
Quote :
you do this: [url] before the URL and then another behind the URL but with a '/' inside the brackets before 'url'
Message edited by rubix_1011 on 06-16-2011 at 04:13:13 PM
Stuff 4 Sale
Reply to rubix_1011
This topic has been moved from the section Overclocking to section CPU & Components by Jpishgar
Reply to jpishgar
There are 2041 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 4 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
