Comments on my first homebuilt system, and need advice on monitor :)
Shawish
Hello all!
I've just put together my first PC! And it all started beause i got the mobo, cpu and psu at less than half price from a hardware reviewer
I've read countless posts in the last three weeks figuring out what to get and have used this site heavily and it has helped alot!.
Now i've finally ordered it all, and i would like to know how good it is (as when i started all this my hardware knowledge was more than 10 years outdated).
I tried making it a beast, but still without breaking the bank. And since most people on here seem to have great experience (and oppinions on pretty much anything
) i figured i'd post my specs here to get some good constructive info/critisism.
Here goes:
Motherboard: EVGA X58 SLI http://www.tomshardware.co.uk/x58-motherboard-i7,review-31520-6.html
CPU: core i7 -920 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Heatsink: Noctua NH-U12P SE2 http://www.newegg.com/Product/Product.aspx?Item=N82E16835608014
PSU: OCZ GameXStream 700W http://www.newegg.com/Product/Product.aspx?Item=N82E16817341002
GFX Card: Sapphire Radeon HD 6950 Toxic http://www.newegg.com/Product/Product.aspx?Item=N82E16814102951
Ram: 3x2 GB G.Skill 1600mhz cl7 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231335
Case: Antec P193 V3 http://www.newegg.com/Product/Product.aspx?Item=N82E16811129176
Monitor: ?
That's the system as it is and it will cost me 1311$ (excluding monitor). Is it solid? Or have i done something completely wrong?
With regards to the monitor i've searched far and wide and cannot determine what i should get. I've looked at ASUS VH242H and all ASUS monitors similar, i've looked at SAMSUNG XL2370 and SAMSUNG P2570. But i can't figure out what to go for. The ASUS monitors available for shipping in my country are a bit lacking (i live in Denmark), so even though i had set my mind on a VH242H i couldn't find a site in europe that sold it.
I am going to use the monitor mostly for gaming, i'll also be using it to write and read alot, and occasionally i'll use it for movies (usually use my tv for that). If possible the monitor should NOT be glossy, i find the reflection very distracting (and it's hard to find one without it :S). It also seem that some monitors have problems with win7 64bit which i plan on using.
Any comments / critique / advice is greatly appriciated
Here goes:
Monitor: ?
86
answers
Last reply
More about comments homebuilt system advice monitor
You mean the CPU? I've read that it can be OC'd easily to 4ghz which is the plan.
If you mean the motherboard. I don't have much knowledge of mobo's, how much impact does it have on gaming and performance? I got it for 140$ which seemed a pretty good deal at the time.
My goal is to be able to run all current games and all future games (the next 4 or so years) at highest or close to highest settings at 1900x1080 btw -
I mean both the CPU and motherboard. The 1366 and i7-??? was released in 2008. Socket 1155 and Sandy Bridge (i?-????) is the current generation. i5-2500K is the current leader in gaming performance.
Now the 1366 isn't bad as such - I have one and it still performs great. I bought it in 2008. You could newer, better tech for cheaper nowadays. -
i might be able to deliver it back, since i am studying on the same university as the guy i bought them from. Could you come with some links to a good mobo/cpu combo for under 450$ combined then?
And still, in what way would it affect gaming performance? Or is it simply that i can get newer stuff at just slightly higher cost? -
You got that mobo+cpu for $450? Then you can get newer and better stuff for cheaper!
Here's a great combo for 367 that's more than enough for gaming: http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.762983
If you have programs that use multithreading look for the i7-2600K. -
Actually I'd still get this mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271 over the combo
+1 for finneousPJ you want a z68 Mobo if you want 4 or more years from it for peak gaming performance, that board and i5 2500k is less than $450 by a good bit, take the extra $ and upgrade your memory to 8gb,
Also not sure if you plan on sli in the future, but if you do I would suggest a 850w PSU, 700 will probably get the job done but I like to have space to play with settings -
I can attest to FinneousPJ's z68 motherboard choice. That's the motherboard I bought, and it's been fantastic. (other than the fact that it doesn't have native USB 3.0 internal headers, but I didn't expect that on a board of this price-point) The only reason you'd want the ASRock z68 Extreme4 rather than the Extreme3 is because the Extreme4 has a third PCIe 2.0 x16 slot for a graphics card or something, while the Extreme3 only has two of those slots. But it's not that big of a deal, and you save $50 by going with the extreme3.
I bought my first computer last month, and these are my specs:
Case: Rosewill Challenger U3
CPU: i5-2500K
GPU: Gigabyte Radeon 6950 1GB
Motherboard: ASRock Z68 Extreme3 Gen3
RAM: Corsair Vengeance 16GB
HDD: Samsung Spinpoint F3 1TB
SSD: Crucial M4 128GB
PSU: OCZ ModXStream Pro 600W Modular
Optical Drive: LG CD/DVD Burner
Extra: Wireless Adapter
Extra: Silverstone PCI Express Card with USB 3.0 Internal Connector
Case Fans: 5 of them. One front, one top, one back, and two side.
All in all, I spent about $1,150, and everything's working great. If you aren't afraid of building in a mid-tower case, I'd recommend the $60 Challenger case over your $180 Antec case, so you can save a bit of cash. I also bought probably double the RAM you need because I do a lot of video editing, so you should only buy 8GB if you plan on just gaming. There's another $50 saved. You might not want the SSD, and so you could spend more money on a bigger PSU or a better graphics card or whatever.
The Noctua heatsink you got is very high quality. You should be pretty pleased with that. I read a bunch of "silent PC" websites that Noctua is one of the top quality brands when it comes to quiet but efficient fans and heatsinks.
The machine you bought isn't bad, it's just that if you're willing to return some of that stuff, it's possible for you to have a better machine for less money.
As far as a monitor goes, I've been doing a bunch of research on that as well, but I've decided that I'm going to stick with my huge LaCie CRT monitor because...I'd rather save a few hundred bucks than have the latest and greatest LCD. However, if I were going to buy an LCD monitor right now, I'd get the Dell Ultrasharp U2412M for $360, since it's an extremely high quality IPS monitor. But since you seem more interested in gaming, you might want a TN monitor instead of an IPS, and you probably want like 1ms or 2ms refresh rates. You might also consider a 120hz monitor instead of the standard 60hz. -
Thanks alot for the replies!
I didn't pay 450$ for mobo and cpu, but 320$. The 450$ was just an upper limit so to speak.
I just don't understand why the ASRock Z68 Extreme3 Gen3 mobo is cheaper than the one i got atmo. If this one is newer and better?
I'm not planning on using multiple GPUs, but the option is nice to have for later. I'm planning to get a SSD, but i don't know much about it (haven't researched about it yet).
Concerning the RAM, from what i could read low latency is just as important as clock speed. And the reason i chose 3x2 was because the motherboard supported 3 ram sticks better than 2 (can't remember the technicalities).
I found this 'formula' to calculate the effect of the ram: (1/(0,5*mhz))*cl And from that it showed that the 1600mhz cl7 scored best. Am i doing it all wrong?
I see that the rams have already been shipped from amazon. How important would you say it is to get some other ram? -
I am quite confused, since it seems that i get contradicting info... In this thread http://www.tomshardware.co.uk/forum/305880-10-current-system-2500k there's a reply saying that going from a lga1366 to lga1155 is actually a downgrade for intel cpu's??
And is the i5 2500k still superior if i also want the ability to have say two games open at the same time, or if i like to have many background programs open while gaming?
Just mailed the guy and he sounded pretty upset seeing as he already spent the money on something else. He was open for finding a solution at least.
For these pieces it will cost me 175$ for the ASRock Z68 Extreme3 Gen3. and 290$ for the i5 2500k cpu.
the motherboard and cpu i currently got was for 320$ as i posted earlier..
Remember i live in Denmark so i can't order from newegg -
Sweden has lower prices than that from what I've seen. Also @ http://www4.hardwareversand.de/home.jsp?lb you can select language
That german site.. you sure they ship to DK? Their shipping details are all in german, even when the language is set to eng
. And the few swedish sites i have found have similar prices
So last question about mobo/cpu would be: How long time would you recon the combo i currently got will run everything at max/close to max ?
I realise that gfx card has most to say in that area, but still?
FinneousPJ said:But anyway if you can't return it it's no biggie. You should have asked before buying though :P
Yeah, Shawish,
Just because you don't have top-of-the-line at this moment, doesn't mean you got a bad deal. You still have a fairly nice machine. You don't need to stress over returning it and ordering all new parts if you're only concerned about running games decently. You've by no means got an enthusiast's machine, but you can still play games with good quality and good framerates.
My advice is to keep what you've got, save up your money, and wait a year or two before trying to upgrade. -
ok. I think it's best if i keep with what i got then. Better to keep the good relationship with my student buddy
Thanks alot for the info though.
@zippycorners: running games decently wasn't the plan, it was to run all current games and the coming releases (sc2hots, d3, bf3, mw3) on ultra. Will i be able to do that with what i got? The way you're saying it brings doubt in my mind -
Shawish said:haha. yeah, that's true. But if i choose to CF, will i have to buy better gfx cards or would a new mobo/cpu with same gfx cards be better?
I'm having a hard time seeing what i'm missing out on with the current mobo/cpu :P
I'm not sure I understand. I'll reiterate: the 1366 is a dead, three years old platform.Shawish said:And if i choose to CF would i need another PSU?
In theory 700W is enough, however I'm not familiar with that particular PSU. You could try and search for reviews online. -
FinneousPJ said:I'm not sure I understand. I'll reiterate: the 1366 is a dead, three years old platform.
What i meant was, when the time comes that 6950 in CF struggles with high settings in games. Will buying new gfx cards (while still using the 1366) give me more of a boost than buying a new mobo/cpu?
Like if there's no errors or the like with the 1366, why not just keep using that untill i need a faster processor? From what i've read it will be a while before the processor i7 920 will be struggling?FinneousPJ said:In theory 700W is enough, however I'm not familiar with that particular PSU. You could try and search for reviews online.
I've read reviews on it that says it's very good. However, it only has 1x6pin and 1x8pin, so i can't CF with it :S. Unless i can get some adapters(or what it's called), is that easy to get? -
Shawish said:What i meant was, when the time comes that 6950 in CF struggles with high settings in games. Will buying new gfx cards (while still using the 1366) give me more of a boost than buying a new mobo/cpu?
Oh. When the time comes that 6950 CF struggles in games (that's hard to imagine) chances are you might need a new processor as well. But I believe that'll be years from now.
Shawish said:I've read reviews on it that says it's very good. However, it only has 1x6pin and 1x8pin, so i can't CF with it :S. Unless i can get some adapters(or what it's called), is that easy to get?
The fact they didn't include the connectors is a sign even the manufacturer doesn't have 100% confidence in this unit. A XFX 650W PSU for example has four PCIe power connectors. I'd look into a different unit. -
I know you can't order from Newegg, but I don't know which other website you want to use, so I'll just let you search for their names.
600W Modular OCZ $50 <-- This is the PSU I bought. I don't plan on CF, so it works great for my single 6950.
625W Modular Enermax Crossfire Certified $100
750W Modular Antec Crossfire Certified $140
775W Modular Thermaltake Crossfire Certified $100
These all have high reviews, are modular, and are pretty good options for CF. Other than the OCZ, of course. -
I've used komplett.se so I'll go with that: http://www.komplett.dk/k/ki.aspx?sku=623449 The TX series is a solid choice for a good price.
Regarding monitors, here's a quote from a Tom's monitor review from April 2011:
"If you're buying a monitor for grandma, there isn't anything wrong with purchasing one of the many budget LCD options available. [However], if you're a gamer, wider gamuts should be your preference because the gamut required to adequately represent the colors in titles like Just Cause 2 is much larger than what's needed to watch an episode of House (which usually uses a smaller and darker color palette)."
According to Tom's reviews, here are the best monitors by size:
24" = Dell U2412M - - - - - - - - ~$350
23" = Samsung's PX2370 - - - ~$200
22" = DON'T DO IT.
I recommend reading the latest monitor review by Tom's, though. The Dell U2412M isn't the only good choice.
Related Resources
Homebuilt
Monitors
Systems
Product
Related Resources
- Tri-Monitor system, need help
- New system build, about $1150 w/o monitor
- Dual monitor top i7 system
- VIA hardware system monitor?
- First Build Review/Advice [$1500] Need Monitor
- First timer 1k gaming build..including monitor
- 3-monitor system: SLI vs. the GTX690
- First build advice $1,000-1,200 inc monitor Gameing PC
- $400 and a monitor.
- Advice on $1000 build with monitor
- Review Request: $1300 build w/monitor
- Help with i7 build Aug/Sep max 1800$ (with monitor)
- SUB 800 Gaming Machine with Monitor
- I7 Gaming Rig for around $1000 w/monitor
- 24", 26" or 28" monitor
