First Time Gaming System, Please Review and Help!
Hey everyone, thanks for reading and especially for replying!
Hey guys,
I recently have been having troubles with my FPS on my Alienware laptop. I have decided since I have my Ipad for portable computing, I can switch to desktops. As building a custom desktop is the best way of getting "bang for my buck" I have decided to take this route. However, I need a lot of help. I really do not know where to start. Does anyone have any recomendations? Also, I am currently in South America. I am going to try and source parts from here but it would be very useful to hear from people who have experience in shipping components, taking them on a plane with you, or having a desktop as "checked luggage". I will be taking a long trip back to Canada soon so I could always bring the parts back with me.
My budget is around $2,000 (CDN/US).
Thanks.
Edit 9/11/2011 (Version 1.1):
Components (Suggestions thus far):
CPU:Intel Core i7-2500K Sandy Bridge 3.3GHz
Motherboard:EVGA P67 FTW 160-SB-E679-KR LGA 1155 Intel
RAM: Please help: http://www.newegg.ca...-Power-Supplies
I would like to pick a combo RAM and Power Supply. G.SKILL Ripjaws X Series 8GB (2 x 4GB) DDR3 2133
Power Supply: See above. OCZ ZX Series 850W Fully-Modular 80PLUS Gold High
Hard Drive:Crucial M4 CT128M4SSD2 2.5" 128GB SATA III SSD
Video Card: 1 x EVGA 03G-P3-1591-AR GeForce GTX 580 (Fermi) Hydro Copper 2 3072MB (Water Cooling)
1 x EVGA 03G-P3-1584-AR GeForce GTX 580 (Fermi) 3072MB
OR two of the Non-Water Cooled
Computer Case:Rosewill THOR V2-White Edition, THOR V2-W Gaming ATX Full Tower Computer Case,
Is it difficult, worth it, necessary to have water cooling? What else would I need for a system like that? Will I have sufficient cooling without the water cooling?
VERSION 2.0:
CPU:Intel Core i5-2500K Sandy Bridge 3.3GHz
Motherboard:ASUS Maximus IV Gene-Z LGA 1155 Intel Z68
Motherboard
RAM: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
RAM
Power Supply:OCZ ZX Series 1000W Fully-Modular
PSU
SSD:Crucial M4 CT128M4SSD2 2.5" 128GB SATA III
SSD
GPU: 2 x MSI N580GTX Lightning GeForce GTX 580 (Fermi) 1536MB
GPU
HD:SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s
HD
Case
Cooler:Noctua NH-D14 120mm & 140mm SSO CPU Cooler
Fan
Arctic Silver 5 Thermal Compound
Thermal Compound
7 answers Last reply
More about first time gaming system review help
  1. since a 2600k will do no better in gaming than a 2500k. save the $100 there and upgrade to a Z68 chipset motherboard and get a regular hard drive for storage. you can partition the ssd to cache the HDD. use 20-40GB intel calls it smart responce technology. but you install the os onto the HDD and install your games onto the remaining space on the ssd. that way your OS boots quickly and your games load crazy fast.
    as for the ram/power combo i found a few.
    best deal i think http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.761121
    fastest ram ddr3 2133 http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.761106
    and most ram 16GB ddr3 1600 http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.761091
  2. oh side note the dual 580s should put your systems power use around 620-650 watts but power supplies should be ran at 80% or less for efficiency and to help it last a long time. so i only looked at 850W power supplies for your combo.
  3. Thnaks for the reply:
    Any recomendations on a Z68 motherboard?
    I was told HDD are very expensive at the moment and to leave it for later. In order to use this partition technology however, I would need the HDD at the time of installing the Operating System, right? Is that hard to do?
    What do you think about taking one 580 with water cooling and one without? I have no idea how these things work... is it needed?
  4. bestbuy hasn't caught on that there is a shortage go there and buy a drive at normal prices.
    i like asus for motherboards mostly because of their uefi design. but they are normally stable. as for exact model i havent checked into them.
    i cant decide on water coolers. i dont want water in my case ever, even if sealed but i dont like the sound that air coolers make.
  5. Ok guys, here is an updated build. Let me know what you think. Also, feel free to comment on compatibility issues or anything else.
    Motherboard
    RAM
    PSU
    SSD
    GPU
    HD
    Case
    Fan
    Thermal Compound
  6. Beast of a build.
    Would tone down on the mobo though. ASUS P8Z68-V PRO or DELUXE would be just fine.
    Unsure about the PSU - Corsair HX1050w now have a 15% sale with a rebate, which is high quality and would end up being cheaper than the OCZ.
    Case alternative: HAF 932
    All that could help save you some change.
  7. Also, please help with this guys:
    I need to source the case from where I live. I will pay out of my ass for it, but it will be less complicated in shipping. Can you help me pick one from this list? The selection in chile is not nearly as good.
    http://pcfactory.cl/?categoria=328&papa=326
    Haf 932 from coolermaster is what I am thinking...
New Build Systems
